How To: Clean Your Wheels and Tires
Old Sep 9, 2010 | 11:31 AM
sullysdetailing's Avatar
sullysdetailing
Default How To: Clean Your Wheels and Tires
I made this video about 6 months ago. It was my first How To: video I made. I am in the proccess of make more. Hope you like it.
http://www.youtube.com/watch?v=uDb8qOxTgjw
If you would like to buy these products, send me a PM and I can give you a discount code to AutoGeek
Old Sep 9, 2010 | 10:49 PM
man thats a lot of work/long time for one tire/wheel....lol....I've found the spray on tire dressings work really well (armorall, etc). just spray on and be done with it. I do like that brush you used to get in the tight spot between the wheel and fender, where did you get that?
Old Sep 9, 2010 | 10:54 PM
sullysdetailing
Spray on silicone dressing is bad for your tires and paint.
I got it at autogeek I send you a PM with discount info
Old Sep 9, 2010 | 11:33 PM
trucky's Avatar
trucky
Is that speed brush pretty flimsy? I need to get behind the spokes but I need something that can scrub back there pretty well not just flop around.
Old Sep 10, 2010 | 01:40 AM
rengnath's Avatar
rengnath
I normally clean the tire and wheel (well) with Wrigleys bleach white and a brush. It works wonders on brake dust and turns the letters on my tires back to pure white. I try to stay away from tire shines because the tire gets dirty much faster, but when I use one I do Mothers Tire Conditioner. It turns the tire black with little to no shine so they dont look tacky.
Old Sep 10, 2010 | 07:54 AM
do you mean westley's bleach white? thats what I use as well, works great for bringing back the white of the tire lettering. Then I use Armor All Extreme Tire Shine Aerosol, but I'm always open to trying new products. I can only speak from personal experience but I've been using "silicone" based tire dressings (read-armor all products) since I first discovered them back in the 80's and have never had a problem with the tires or paint from using them. I don't doubt the claims they can harm tires, but I've just never personally experienced any tire issues from using these products. I counter that, if you dress your tires often (at least once a week for me) then you offset any negative effects these products may cause over time because you always have a fresh layer of tire shine on them. : )
Old Sep 10, 2010 | 08:46 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Westley's is my number one cleaner I use NXT Extreme Tire Shine on my truck for the clean look, its in an aerosol. That stuff is pricey but it lasts a good while.
Old Sep 10, 2010 | 09:23 AM
sullysdetailing
It is and isn't if you use a good wheel cleaner like DP Gel Wheel Cleaner or P21S Wheel Gel you let the product duell and it does most of the work for you. I like the Speed brush because you can bend it to get the back side of the spokes and brakes ect. They make Deep Reach Wire Wheel Brushes that you can scrub pretty hard with the the brissel are not that soft so only use it for the inner hub of the wheel
Old Sep 10, 2010 | 09:33 AM
sullysdetailing
Only use Wrigleys on tires over time it will turn the plastic in your wheel wells light and light. Also try not to get any on the wheel it self.
No for tire shine, there are much cheaper/better product out there that are not silicone dressing that will give you a great shine and no harm your wheel, tire or paint. If you guys like a matt or semi gloss finish to your tires use DP Gloss Tire Gel. For matt finish apply onto your tire let it sit for 5-10 minutes and wipe off. For semi gloss finish apply evenly only the tire and let it sit unit it all soak into the tire. After 30 minute wipe an residue. For a higher gloss use Poorboy's Wolrd Trim Restore. Apply evenly on the tire and wipe off after 30 minutes (the tire should of soak almost all of it up)
No unlike silicone spray on the dressing that sit on top of the tire these dressing soak into the tire conditioning the tire. Being that it soaking into the tire there is no fling off when it is raining. Being that you wipe it on you dont have to worry about getting those nasty silicone dressings on your paint and wheels
Old Sep 10, 2010 | 09:53 AM
lghtngblt02
Interesting, I'll look into that. I am up for trying new things if it works well.
