New off road lights - one won't work!
Old Sep 15, 2010 | 02:46 AM
canadian dakota's Avatar
canadian dakota
i know one of my grill lights has a bad ground itll go on and off pending on road surface
i crimped my roof lights never had a problem and solder and shrunk my grill lights and constantly had to fix them the bad ground was the breaking point they stay off now im moving them soon anyways
and as for hammers tip good call i allways test outta the box as well and re test after upgrading the 55w bulbs
Old Sep 15, 2010 | 03:17 PM
Odynn77's Avatar
Odynn77
Yeah, I did the crimping and put cold weather electrical tape over the ones that have worked. At least they're covered and in place. It may be a better idea to shrink wrap them once I get the "unhappy" bulb figured out.
Old Sep 15, 2010 | 03:19 PM
Odynn77's Avatar
Odynn77
Any thoughts on something like liquid electrical tape or that 2-sided electrical tape that also seals out moisture for low-voltage stuff to cover the quick M-F disconnects or is shrink wrap still the best bet?
Old Sep 15, 2010 | 05:54 PM
I use both. depending on how lazy I feel at the time. never had a problem with either.
Old Sep 16, 2010 | 03:06 PM
Odynn77's Avatar
Odynn77
Swapped the bulbs out - worked in the other light. Gotta go back over the wiring. I guess I'll be acquiring a 12v circuit tester soon...
Old Sep 16, 2010 | 05:54 PM
HammerZ71's Avatar
HammerZ71
You got to have a bad connection someplace between that light and wherever you met power wire to the other light. Either that or that light ain't grounded...
Old Sep 16, 2010 | 06:39 PM
basic thing to have for any electrical work, either a test light or a cheap digital multimeter (dvm) from radio shack, or somewhere, heck, even walmart sells them nowadays. If one light works from the switch, you know that you have wired the circuit up correctly, i.e. a change in the switch state (on/off) equals a change in light state (on/off), so now you need to trace the wiring and find out where you are losing the 12 volts to the light that does not work. Check all your connections. Normally in these types of circuits, the main 12 volts coming from the switch or relay (depending on how you wired the circuit) will be "T"'d, so 12 volts will go to two lights from one source....start tracing, measuring and troubleshooting...
Old Sep 16, 2010 | 10:07 PM
Odynn77's Avatar
Odynn77
Yeah, the issue has got to be between the splice connector and the light. Either the wiring from the connector to the light or the ground itself. Thanks for all the hints. Gotta keep digging.
Old Sep 17, 2010 | 06:36 PM
Odynn77's Avatar
Odynn77
Got some new info: took the truck in for an oil change today and asked my local guys to check it out. They told me I've got power running to the ground on the one light as well as the wiring to the bulb. How does that happen? I've got both lights grounded to the bolts for the hood latch. I'm going to double check the schematic, but my guy told me it may be an issue in the relay. Any other thoughts?
Old Sep 17, 2010 | 07:18 PM
trucky's Avatar
trucky
One word. ProComp. The end.
