Yet another 05 Vibration issue
Old Oct 10, 2010 | 03:50 PM
MagpieTear's Avatar
MagpieTear
Default Yet another 05 Vibration issue
Hi all, unlike most others with the vibration issues, mine conveniently waited until I had 66k on the clock and was 400 miles from home in Friday rush hour DC Beltway traffic. It's a horrible shudder under acceleration, a thrum/binding feel while moving (much worse with the clutch engaged, still there, but barely noticeable when I push in the clutch while moving) and the infamous rear end hop under braking.
My question is, being it took so long to occur, the fact that I am 5 years and 66k into ownership, and the dealer I bought it from long gone, what sort of chance do y'all think I have at getting this thing fixed according to the TSB's under the 7/70 warranty?
It's an 05 SLT, 3.7, 6 spd, 8 3/4 rear with 3:55 gears
I'm not a gearhead, I'm a patternmaker, so I can't tell if it's the clutch, tranny, or rearend that feels like its dragging, but as I limped home yesterday on the PA turnpike, I could smell hot gear oil, and now I'm a bit concerned after reading some of the horror stories on this forum.
BTW, this is my 3rd Dakota, had a 93 and a 97, loved both of them, the 93 was totaled after being broadsided in an ice storm, and the 97 was traded in on the 05 after 182k on the clock. I'd really like to get 10 years out of this one if possible, and will seriously look into the slotted rotor upgrade once this issue is sorted out.
Old Oct 10, 2010 | 04:00 PM
you sure the clutch isn't burning up? Most of the vibration issues I have from the rear end come when braking, not accelerating. I believe the TSB had to do with high speed shudder while braking, so if yours is happening while accelerating, that sounds like a different issue....i never had any rear "hop" while braking either, mainly just an annoying shudder that only happens sometimes. I've learned to let off and apply the brakes again when it does happen and it will go away.
Old Oct 10, 2010 | 04:05 PM
MagpieTear's Avatar
MagpieTear
It very well could be, I don't know. But it was odd that I could smell the fluid yesterday around the back of the vehicle. No mistaking the scent of hot gear oil. I never needed to replace the clutch on the 93, it was killed before I had any issues. I did replace the one on the 97, but it was slipping at 120 k or so, there was no chatter or noise. But if it is the clutch, I'd be happy, that's a wear item, not a quality issue. Well, happy until I get the bill...
Old Oct 10, 2010 | 05:23 PM
gear oil smell from the rear could also mean something bad is going on in the differential/axle housings...
So the vibration is there with or without the clutch being engaged? More points to something in the rear end or drive shaft/u-joints...have you jacked the back up and spun the wheels with it in neutral? That could help isolate.
Old Oct 12, 2010 | 07:51 PM
MagpieTear's Avatar
MagpieTear
Well, I dropped it off at Monroeville Dodge. Hopefully I'll have something to report tomorrow. Also hope it doesn't take too long, supposed to rain Thursday and Friday, and a wet 22 mile commute at 4 am on a motorcycle isn't fun in October...
Old Oct 12, 2010 | 08:49 PM
Moneyman19's Avatar
Moneyman19
monroeville dodge? u mean spirit dodge in swedeseboro nj? from what it sounds deff sounds like sumthing might have gone wrong in the rear... we'll not bad of a time to look at new gears
Old Oct 13, 2010 | 09:12 AM
superdak05's Avatar
superdak05
there is a c-clip that dodge uses while assembly the rear end, it holds everything together, these clips are notorious for falling apart and getting caught in the gears could be heading into failure, thats why dodge wants people to have their gear oil changed so they can remove this clip
Old Oct 14, 2010 | 05:53 PM
WTEBOY703's Avatar
WTEBOY703
hmmm did not know that superdak good to know
Old Oct 14, 2010 | 07:25 PM
MagpieTear's Avatar
MagpieTear
Well, it's a good thing I'm not a mechanic, a lot of vehicles would apparently die at my hands. It was the rear universal. Two of the bearing caps were frozen solid. The pinion bearing preload was also out of spec, whatever that means. But it rides like a whole new truck now, thanks all. Hooray for the 7/70 warranty!
The last time I had a problem with a u joint, there was no vibration like this, it was more noisy than anything else, and a noticeable clunk when putting it in gear. That was on a 1978 Volare' when I was a teenager, back when Dodge's small truck was the D-50. Guess I'll leave the mechanical work to the pros and stick to wrenching on motorcycles. Tighter tolerances, but much easier to access and understand for me.
Moneyman, Monroeville Dodge is just SE of Pittsburgh, PA.
