HELP! squeaking front end
Old Oct 14, 2010 | 06:29 PM
HMI's Avatar
HMI
Default HELP! squeaking front end
help!
my front end is squeaking really bad! 2007 dakota v6
My best guess is that it is my ball joint as when i turn the wheel from one side to the other it creeeeeeeeeaks like a spring, and when I raise it by a jack it squeaks worse! i've lubed everything and changed the stabilizer links.
is it my ball joint? please help.
is there a link for instructions on how to change a lower ball joint on 3rd gen dakotas?
Old Oct 14, 2010 | 06:31 PM
rengnath's Avatar
rengnath
My money would be on the ball joint(s) .... the crappy struts from the factory cause premature wear on everything up front.
If youre looking at doing them yourself, you probably should just replace all the ball joints up front so you only have to get one alignment. Struts would be a great idea as well if you have a spring compressor.
You can find anything youve ever wanted to fix on your truck in the sticky at the top of the 3rd gen dak section. Its a huge download, but it has everything. And its free! Good luck!
Old Oct 14, 2010 | 10:41 PM
hendrixx324's Avatar
hendrixx324
yea my truck did the same thing and it ended up being my bakll joints
Old Oct 15, 2010 | 02:08 AM
nicholas9393's Avatar
nicholas9393
deffinately ball joints. same story here
Old Oct 15, 2010 | 06:18 PM
HMI's Avatar
HMI
thanks guys. thats what it does seem to be.
Old Oct 16, 2010 | 01:48 AM
Shibby927's Avatar
Shibby927
Yeah I have heard bad things about the ball joints from a lot of people who own dakotas. The front ends of these trucks leave much to be desired. I just had to spend something like $800 replacing the entire rack and pinion after a tie rod end broke off on my passenger side. Good luck to you.
