2008 tire size
Old Oct 15, 2010 | 06:57 PM
Bugz2008's Avatar
Bugz2008
Default 2008 tire size
I know there are a few theads discussing tire size, but all the answers I see are 2007 and under...anyone know what the biggest size tire is that will fit on a stock 2008?
Tire rack lists 265/70/16 as an optional tire size, will they fit with no tire rub on a nonlifted or leveled truck?
Also, anyone running Definity Dakato A/T's? $114 a tire, and Pep boys does the buy 3 get 4th free, quoted me 4 tires installed with road hazard for a shade over 400. Same wear, traction, and speed rating as the BFG's, and the tread pattern looks so close I can't imagine why someone hasn't been sued. just wondering if anyone is running them. Also thought its kind of cool to have a Dakota tire on well...a Dakota.
Old Oct 15, 2010 | 07:14 PM
dakotaff's Avatar
dakotaff
It's the same tire size for all 3rd gens (05-11).
265/70/16 will fit on with stock suspension without any modification.
265/75/16 will fit with a leveling kit and will also require some trimming due to rubbing. How much trimming depends on the tire that you choose.
Old Oct 15, 2010 | 07:34 PM
canadian dakota's Avatar
canadian dakota
um im running 265/75/16 on an 08 no lift no level if anything its sitting a little lower than it should due to needing new struts never had an issue with any rub (its about time for new tires to ) maybe the wheel well is a little bigger with the new styling IDK
Old Oct 15, 2010 | 07:48 PM
dakotaff's Avatar
dakotaff
Ok, I stand corrected. I always thought we all had the same clearance.
Old Nov 15, 2018 | 09:50 AM
Tara M's Avatar
Tara M
hi just wondering which model you have with using the 2657516s
Old Nov 15, 2018 | 10:32 AM
dakotaff's Avatar
dakotaff
He had a 2008 Dakota SXT 4X4, upgraded to a Ram 1500 a while back. Not sure if he is still active here on DF.
Welcome aboard.
