my Build Sheet question
Old Oct 20, 2010 | 08:05 PM
WTEBOY703's Avatar
WTEBOY703
Default my Build Sheet question
okay i got my build sheet today and it has on there 22 GALLON TANK then below it it says 3 ADDITTIONAL GALLONS OF GAS. was this an extra option or something? lol it says heavy duty shocks? lol
MY BUILD SHEET
*P9 Cloth 40/20/40 Split Bench Seat
-D5 Med Slate Gray
ADJP Heavy Duty Service Group
AHC Trailer Tow Group
AJKS Convenience Group
AJPS Power Convenience Group
APAS Monotone Paint
A82P 4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BCSS Run Down Protection Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CBZS Prem Vinyl Door Trim w/Map Pocket
CDLP Manual Driver Lumbar Adjust
CFNS Rear 60/40 Folding Seat
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUZP Center Armrest Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHTP Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GUNP Power 6X9 Multi-Func F/Away Mirrors
GXRP Keyless Entry
HAAS Air Conditioning
JAAS Instrument Panel
JA2S Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
JPSP Power 6-Way Driver Seat
KRXS STRIPE/BADGE/MOLDING/COLOR
K8AS STRIPE/BADGE/MOLDING COLOR
LACS Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LCDS Map/Dome Reading Lamps
LHES Rear Dome w/On/Off Switch Lamp
LMBS Halogen Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MBES Bright Rear Bumper
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MUMS Dakota Badge
MUZS SLT Badge
NAS 50 State Emissions
NBKS EVAP Control System
NBQP Federal Tier 2, Bin 10A Emissions
NFBS 22 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NHJP Exterior Mirrors w/Heating Element
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
NZDS Next Generation Engine Controller
PSB Bright Silver Metallic Clear Coat
QSBS Bright Silver Metallic Clear Coat
RCDS 4 Speakers
RDDS Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXV P265/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WDQP 16" Steel Spare Wheel
WD1S 16X8.0 Cast Aluminum Wheels
XBSS Pickup Box
XCAS Occupant Classification System
XDXS Scissor Type Jack
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XSLS Brake/Park Interlock
X81S Instrument Panel Parts Module
X88S Tire & Wheel Parts Module
YAAS Build To U.S. Mkt. Specifications
YGSA 3 Additional Gallons of Gas
ZAUP Spring - Left Rear
ZCGP Spring - Left Front
ZNUP Spring - Right Rear
ZRFP Spring - Right Front
5I4S Four Wheel Drive (4WD)/(4X4)
5ZGS 5 FT. Cargo Box
5ZKS Quad Cab
5ZZS ND-Vehicle Family
Old Oct 20, 2010 | 08:47 PM
dakotaff's Avatar
dakotaff
I'm not sure what that means, but I have the same thing on my build sheet.
Old Oct 20, 2010 | 09:03 PM
SLT07Dakota's Avatar
SLT07Dakota
I believe thats the reserve amount when your fuel light comes on.
Old Oct 20, 2010 | 09:18 PM
superdak05's Avatar
superdak05
my build sheet says, must be driven hard and beat all the time in order for everything to work properly, so i abliged,
Old Oct 20, 2010 | 10:25 PM
dakotajerry's Avatar
dakotajerry
Thats the gas they put in it to get it out the factory to the dealership
Old Oct 20, 2010 | 10:49 PM
hendrixx324's Avatar
hendrixx324
How do they do you get your build sheet again?
Old Oct 20, 2010 | 10:53 PM
WTEBOY703's Avatar
WTEBOY703
https://dodgeforum.com/forum/3rd-gen...ild-sheet.html
Old Oct 20, 2010 | 10:54 PM
WTEBOY703's Avatar
WTEBOY703
does everyones else say HEAVY Duty shocks?
Old Oct 20, 2010 | 10:56 PM
hendrixx324
Thanks ill let ya no when i get mine
Old Oct 20, 2010 | 10:58 PM
WTEBOY703's Avatar
WTEBOY703
hooah i had a 3 hour turn around time...sent it in at 1 pm at 4pm it was in my inbox!
