Oxygen Sensors
Old Oct 25, 2010 | 03:15 PM
rengnath's Avatar
rengnath
Default Oxygen Sensors
How many do we have?
Im guessing one before each cat, and one after each cat; so a total of 4. Is this correct or are there more downstream by the y-pipe or up by the manifolds?
Also, to remove them do all I need is a regular wrench and turn them counter-clockwise?
Thanks guys.
Old Oct 25, 2010 | 03:35 PM
rengnath's Avatar
rengnath
Alright, Im getting confused on what part numbers I need for different O2 sensors on the sites. If I only need 4, it looks like 3 are the same and 1 is different.
From Rockauto.com
Upstream Right and Left, Downstream Right - Bosch #13937
Downstream Left - Bosch #13775
Can anyone confirm that one would be different?
Old Oct 25, 2010 | 03:52 PM
Oreilly's lists these for Bosch:
#13775 - downstream left
#15733 - downstream right
#13937 - upstream, 2 per vehicle
Why are you replacing all 4?
Old Oct 25, 2010 | 04:03 PM
rengnath's Avatar
rengnath
Because Im at 112k and they havent been replaced yet. The recommended replacement is at 100k so I figured for $150 its not the worst thing to replace.
.... and Im trying to see if it helps my rough idle. Eimer said my truck idles noticably rougher than his. I do like it rough, but Id prefer my idle to be smooth. Lol
Old Oct 25, 2010 | 04:05 PM
rengnath's Avatar
rengnath
Alright, Advanced is showing the same thing that Im finding on Rockauto; 3 are the same, 1 is different. But Oreillys is giving a whole different part number for the right downstream.
Update: Autozone is showing 15733 as a universal O2 sensor
I went ahead and bit the bullet. I ordered 4 O2s from Rockauto for $148.95 shipped. I hope to see some better performance with the new ones .... but I wont keep my hopes up too high. From what Ive read, replacing old O2 sensors is a good idea to avoid future problems caused by fading O2s that arent triggering an engine light yet. Now hopefully I can replace them all myself ....
Old Oct 25, 2010 | 08:04 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Be aware that even an applicable Bosch sensor may cause issues. I replaced my Bank 1 pre-cat sensor @ 80K with a Bosch unit and had nothing but CEL codes every other day. Put the original sensor back in with 80K on it, and it hasn't thrown a code in 9K.
Old Oct 25, 2010 | 08:05 PM
rengnath's Avatar
rengnath
Did you every figure out why the bosch caused problems? I thought they were a pretty reputable company ....
Old Oct 25, 2010 | 08:07 PM
rengnath's Avatar
rengnath
And while Im thinking about it;
Is the following correct?
Bank 1 = Left side = Drivers side
Bank 2 = Right side = Passangers side
Old Oct 25, 2010 | 08:47 PM
if your sitting in the drivers seat...lol....I always double check because you never know....I ordered a "right side" marker light for my sons ZX2 and i asked if that was drivers or passengers, in that case, their "right side" was drivers, i.e. looking at the front of the car.
Old Oct 26, 2010 | 04:23 AM
WTEBOY703's Avatar
WTEBOY703
yeah right bank is drivers side left bank is passenger side! its looking at it from the front of the vehicle!
