Lift Spring
Old Nov 16, 2010 | 02:50 PM
Churchboy's Avatar
Churchboy
Question Lift Spring
Has any one tried this out, instead of the lift block in the rear, just curious?
got me thinking that one can achieve a two inch lift plus additional towing and carrying capabilities, rather than just a lift with the block
http://cgi.ebay.com/ebaymotors/Dodge...item3a4b96dfe4
Old Nov 16, 2010 | 03:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes they will work. I did a similar thing. I took a Ram 2500 leaf spring which lifted it up. The actual lift will be less then they say due to specific weight ect.
I hate cheater blocks, by the way I say go for it and get a real suspension lift.
Old Nov 16, 2010 | 03:23 PM
Churchboy's Avatar
Churchboy
i would like to but there are no suspension lift for our trucks
Old Nov 16, 2010 | 04:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The ADL Add A Leaf is a suspension lift.
Old Nov 16, 2010 | 05:25 PM
Churchboy's Avatar
Churchboy
ok kool i will
Old Nov 16, 2010 | 06:18 PM
i think you mean there is no suspension lift for the front with the exception of the leveling kit. Thing is, if you use this leaf to raise the back end, you will have even more of a rake if you don't have a leveling kit, and if you do have a leveling kit,then you will be right back where you started with the rake, only higher....so whats the point?
Old Nov 16, 2010 | 06:26 PM
gjmoran's Avatar
gjmoran
height my man, height
Old Nov 16, 2010 | 06:27 PM
gotcha
Old Nov 16, 2010 | 09:21 PM
Churchboy's Avatar
Churchboy
but wont it be the same as putting on the leveling kit up front and the blocks in the rear ???
if it is ; then i would think that this method would be better that the blocks, since u are not only getting the added height but more towing and carrying capabilities ???
Old Nov 16, 2010 | 10:19 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Its the best way to setup the rear. There is no good way to lift the front however....
Just an assortment of junk leveling kits.
