A-Pillar Gauge Pods
Not that I would want it for gauges, but how hard do you think it would be to mount a small monitor for a back up cam and/or use the pod for a cluster of switches (k/c light, train horn, interior led, etc.) ?
Shawn:
We do not have a unit for that year range.
The minimum order for most double or triple units is 30. If some want double and some triples that would entail two projects and require two minimum orders. So try to get everyone to decide on one set up. We cannot give a good price until we see the trim piece. If it is a straight forward thing then it should be around the $40-50 range. Also, we will need to know exactly where all the airbags/curtains are located (even if it is an option).
Email a couple photos of you’re a-pillar and dash area.
We will wait to hear from you.
Best regards,DennisLo-Tek, Inc.
Please forward all prior correspondences and attachments when replying.
(Alex) might as well get on the list for this, i'm dreaming of a supercharger and would need space for gauges if it ever comes true,
2 gauges is enough for me if that is going to be the next question
no its a whole pillar not that tacky screw into the pillar you already have! basically once this gets done you'll have anew A-pillar to put in and take your stock one out!
