A-Pillar Gauge Pods
Old Dec 9, 2010 | 12:39 AM
  #31
SilverGhost1's Avatar
SilverGhost1
Sully, I'm in. So, who's on the list? How many more do we need?
Old Dec 9, 2010 | 03:42 AM
  #32
WTEBOY703's Avatar
WTEBOY703
I already said i'm in on that!
Old Dec 9, 2010 | 04:09 PM
  #33
sullysdetailing's Avatar
sullysdetailing
Well I started to make a single gauge pod for my truck so I can keep the handle. I have a friend that is pretty good with fiberglass I am going to have him look at the stock pillar and see if he can fit two gauges in there if so then you can send them to me and he can make em for you guys
Old Dec 10, 2010 | 02:24 AM
  #34
WTEBOY703's Avatar
WTEBOY703
thats just more work for us...lol i mean on fort hood you can roll around with pieces of your truck missing from inside or outside..how much are the stock ones? research time!
Old Dec 10, 2010 | 07:23 PM
  #36
marcsnyder05's Avatar
marcsnyder05
how hard would it be to put a transmission temp gauge in?
Old Dec 10, 2010 | 07:27 PM
  #37
Eimer123's Avatar
Eimer123
https://dodgeforum.com/forum/3rd-gen...gauge-diy.html
Old Dec 10, 2010 | 07:57 PM
  #38
bruno426's Avatar
bruno426
Not that bad to do gauges of any sort. Personally I want an actual oil pressure gauge, not just a dummy light.
Then a AFR gauge
And if we get one that fits three, I am using the last one as a section to put a couple switches for my air compressor in.
Old Dec 10, 2010 | 07:59 PM
  #39
rengnath's Avatar
rengnath
I would the an AFR gauge, but they need a wideband to actually help you understand your fuel mixure .... and thats to pricey for my tastes.
Old Dec 11, 2010 | 01:40 AM
  #40
dodgetrucker75's Avatar
dodgetrucker75
Originally Posted by ericemery
40 bucks is pretty dang cheap... I would recommend staying away from glowshift if you want accurate read outs... My wideband on the talon was WAY off and the oil pressure worked for a couple weeks. voltage was fine, but EGT was a mile off too.
I ended up with Autometer. cant go wrong there.
yup, i will never have anything other than autometer, bout as good as it gets, i have 18 of them between my 3 trucks, but soon to be 21
its some what easy, i T-ed mine in the hot side cooler line just before the radiator, its a lot hotter than the pan will ever be, but if you go by it, you will never scoarch the fluid,
also, remember guy's... the 3rd gen ram coluom pods are a direct fit for the dak's
