How do i check my engine light codes?
Old Dec 2, 2010 | 01:30 PM
baracis's Avatar
baracis
Default How do i check my engine light codes?
I forget the key cycle for checking my codes. I live in a rural area so I don't really want to run to auto zone if I can help it. Any help would be great, thanks!
Old Dec 2, 2010 | 05:33 PM
baracis's Avatar
baracis
No one knows I take it?
Old Dec 2, 2010 | 06:05 PM
dakotaff's Avatar
dakotaff
Give this a try.
To check your engine codes:
-Turn the key to ON (not start), OFF, ON, OFF, ON and leave it there.
-If you look in the odometer window the codes will flash any code(s) with a small delay between each result. Each code should be in a P#### format, and will say PDONE when completed - turn your key to OFF and remove. Use the OBD code list to determine what problem the computer detected.
Old Dec 2, 2010 | 06:45 PM
Blown287's Avatar
Blown287
Do you still have the Superchips Cortex? It has a code reading function.
Old Dec 2, 2010 | 07:07 PM
rengnath's Avatar
rengnath
I didnt think our Daks had the ability to display codes ....
Old Dec 2, 2010 | 07:13 PM
Eimer123's Avatar
Eimer123
Yea I tried the sequence on my truck and I failed. I guess I will add this to my "I suck at life list" LOL Hope the SC Flashpaq can read codes.
