Headlight Questions
Old Dec 3, 2010 | 06:04 PM
trevorrawson's Avatar
trevorrawson
Default Headlight Questions
When I switch on my brights the passenger side headlight goes out. I thought that it might just be the bulb so I bought some new ones and replaced them. Went to turn on my brights and it's still not working. Anyone know if this could be a fuse problem or am I going to have to replace the whole headlight? I looked at the fuse box but couldn't figure out which one went to the headlights. I've still got a few weeks on my dealers warranty so I think they'll cover it. But I'd like to not have to replace it and have one bright and shiny new one and one kind of old and faded. I'm going to replace them eventually it's just not up high on my list of things to do at the moment.
Old Dec 3, 2010 | 06:19 PM
rengnath's Avatar
rengnath
The problem sounds to be in the wiring and not the actual housing so their will be no need to replace the actual headlight. When you turn on your brights, the wires that run your regular lamps shut off. It sounds like there is a fault in the wire that runs your bright on that headlight. An electrical tester should be able to point out which wire is which. Could be something as simple as the connection being corroded.
Old Dec 3, 2010 | 07:00 PM
Eimer123's Avatar
Eimer123
I am pretty sure our headlights run through a relay in the fuse panel. I do not recall what # location it is in, but you can always try switching the relay with another one temporarily to see if it fixes the issue and then buy a new one if that is the problem.
Old Dec 3, 2010 | 08:25 PM
trevorrawson
I thought that it might be a relay as well but the fuse panel didn't even have headlight listed. They had a number of parking lamps and such. Any idea at what it might be labeled as? I'm going to check out the wiring tomorrow, hopefully it's something as simple as a bad relay or corrosion.
Old Dec 3, 2010 | 10:25 PM
Check out the service manual in the sticky section:
https://dodgeforum.com/forum/3rd-gen...ce-manual.html
In the section about exterior lighting, they talk about a control module and using a scan tool to read it...sounds like there is a control module that has a problem, or check the light connector itself like rengnath said.....could be corroded for the high beam on that side.
