brake vacumme hose
Old Dec 24, 2010 | 04:52 PM
jnd03's Avatar
jnd03
Default brake vacumme hose
guys i did the sea foam thing to my truck to see if it would improve my mpg (11.5) my truck now only stays on if im driving it or have it on D (drive) as soon as I put it in P (park) the rpms start bouncing around from 800 - 400 till it eventually shuts off. I noticed that if i unplug the brake vacumme hose the problem goes away...
any ideas?
Old Dec 25, 2010 | 08:11 AM
WTEBOY703's Avatar
WTEBOY703
make sure the vaccum hose is properly put on both ends...could have came loose a little just try it again and if not try disconnecting the negative side of the battery! basically negative battery disconnected for an hour is the auto reset button!
Old Dec 25, 2010 | 02:47 PM
jnd03's Avatar
jnd03
Thanks will let you know
Old Dec 26, 2010 | 10:40 AM
jnd03's Avatar
jnd03
hey man just wanted to let you know that it worked, thanks alot but now it seems that at idle my rpms are much lower than before. at idle im between 600-700 as before i was always near 800
Old Dec 26, 2010 | 10:44 AM
WTEBOY703's Avatar
WTEBOY703
thats fine mine nothing to worry about does it run fine and stay running?
Old Dec 26, 2010 | 02:58 PM
gjmoran's Avatar
gjmoran
mine idles around 700-750 or so
Old Dec 26, 2010 | 07:18 PM
jnd03's Avatar
jnd03
its stays on, but if im driving around 70mph and put it on neutral it shuts off.
Old Dec 27, 2010 | 04:37 AM
WTEBOY703's Avatar
WTEBOY703
uhm can i ask a dumb question? why when your doing 70mph do you put it in neutral? lol?
Old Dec 27, 2010 | 10:13 PM
jnd03's Avatar
jnd03
I dont normally do that, but since i knew that at idle the truck would shut off I wanted to see if the truck would stay on neutral.
Old Dec 28, 2010 | 12:47 AM
WTEBOY703's Avatar
WTEBOY703
oh okay...well idk man anyone have any ideas on why this is happening!?
