Question is...do you need the Supercharger for this? if not i wouldnt mind doing a homebrew hehehe
Yep, you can make the kit yourself. Here is the one Winston and I are talking about. I know someone who actually installed this very kit on an SRT8 Magnum. http://www.snowperformance.net/product.php?pk=31
As long as you run a 50/50 mix of meth or ethanol to water you will be good to go. Anything more than 50% alcohol is a flammable substance and not a good idea to use with a setup like this. You also want to ensure the nozzle size you pick will work with a naturally aspirated setup. You do that, and you will be good to go.
How much power can you gain from this with a n/a motor? Im just wondering if it would be worth the $300-$500. Also blown how long does your tank last it looks like the size of the tanks in the kits are small.
My father would kill me if he ever saw something like this under my hood.
Now I understand that it is on a switch connected to some vacuum line.
So this would mean that it would onily turn on when the engine hits a certen rpm's?
Does squirting this stuff into the intake make the truck's cel come on for any reason?
My tank is 1.5 gallons and in the summer I fill it up about every two weeks. You can get them in up to five gallons but on a naturally aspirated setup it would take a year to use it up, lol.
Mine is a boost pressure switch. As the supercharger hits 3psi it opens a terminal giving power to the pump. You can also have an inside cab toggle switch, as I do also.
It never has on mine but on a NA setup you wont to stay with the smaller nozzles.
