Flasher or Computer
Old Jan 4, 2011 | 10:32 PM
timarc124's Avatar
timarc124
Maybe you could go to your dealership to reprogram the flashing rate. I don't know if it's possible.
Old Jan 4, 2011 | 10:42 PM
Blown287's Avatar
Blown287
Originally Posted by VConfreda
So I gess there is no way to have a flasher that wont go into hyperflash mode due to it thinking there is a bulb out? And that load resisitors are the onily way?
Wow, I have no idea brother. I simply looked the part up for you, lol. I've never messed with them.
Old Jan 6, 2011 | 03:14 PM
VConfreda's Avatar
VConfreda
Hmmmmn.... Do the load resisitors use a lot of power? If I did convert to leds and use load resisitors, would it make the voltage bounce around less with the 4 ways on?
Old Jan 6, 2011 | 03:48 PM
how much does your voltage bounce with the 4-ways on? sounds like there is another problem, mine does not bounce around.
Old Jan 6, 2011 | 04:20 PM
VConfreda's Avatar
VConfreda
Not alot probally around .4 volts or so. However it is sometimes enough to change the briteness of the guages a small amount. And for some reason it bugs me alot. I am thinking of just getting a big compacitor and wireing it to the battery to see if that makes a difference. However I really want leds regardless lol.
