almost crash my truck...my horn is not loud enough!!!!
Old 01-19-2011, 09:31 PM
tdister's Avatar
tdister
tdister is offline
Another nod to the hella supertones. High quality, compact/easy to install right behind the grill, reasonably inepensive. They are also louder than most horns from the tests I've seen performed, no matter whatt he boxes rate them at. They don't sound pretty or "cool" IMO, they sound nasty and ugly...and like something you want to get out of the way of.
I've had some cheap replacement horns fail, and I've heard of air horns not being reliable (valves getting stuck or something).
I have the supertones on mine and, while you can use the factory wiring, I used a relay system activated by one of the factory horn wires, leaving one of the factory horns operable too (total of 3 horns). The relay is easy, allows the factory wiring to remain 100% stock plus makes sure the hellas are getting all of the voltage they need to be full volume.
  #22
Old 01-19-2011, 09:46 PM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
The RAM Administrator
Dodge Forum Administrator
Hey could you maybe do a little write up... I'd be interested in seeing your set up
  #23
Old 01-19-2011, 10:05 PM
rengnath's Avatar
rengnath
rengnath is offline
  #24
Old 01-19-2011, 10:08 PM
Eimer123's Avatar
Eimer123
Eimer123 is offline
WOW I likey!!!!
  #25
Old 01-19-2011, 10:13 PM
rengnath's Avatar
rengnath
rengnath is offline
I wonder if he wears his ear protection while driving .... just incase someone cuts him off. Lol
  #26
Old 01-21-2011, 12:11 AM
tdister's Avatar
tdister
tdister is offline
I'll see what I can do. Hopefully a comparison vid beside my buddy's dodge ram. Just need to get my camera back...
It's pretty simple. I mounted the horns on the beam/support behind the bumper and grill. I'm pretty sure the supertones came with the relay, not 100% sure though. I did remove one of the horn grills for clearance reasons.
I'd intended to reposition mine at some point as one of the horns is partially blocked by the bottom of the grill when the hood is closed. I haven't done it because there is just no need. I find myself already not using my horn sometimes for fear of scaring the innocent...
There are some youtube vids of them, mostly on subarus. the vids don't really do them justice but give an idea.
  #27
Old 02-13-2012, 09:15 PM
norma jean's Avatar
norma jean
norma jean is offline
about that write up.......
  #28
Old 02-14-2012, 03:32 PM
varnerhba's Avatar
varnerhba
varnerhba is offline
ive seen in a previous thread you asking about train horns, at our local truck shop we can get them for about 300$ you just need a different fitting, and WTF FML they are LOUD im in orang county ca.....
  #29
Old 02-14-2012, 03:48 PM
jkeaton is offline
that was from last year......don't even know if that guy is on here anymore...
  #30
Old 02-14-2012, 03:50 PM
norma jean's Avatar
norma jean
Unhappy
i know, but i like to think i can have hopes and dreams
Quick Reply: almost crash my truck...my horn is not loud enough!!!!
