will this work for 33s?
Old Jan 14, 2011 | 05:52 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Hendrixx, if you are unsure if you have an open diff or lsd, go to your dodge dealership and get a vehicle build sheet. It will tell you. Otherwise, if you have an lsd...and you go to install your powertrax, you may be disappointed when you have to stab the cover back on and fill it with synthetic fluid again.
Old Jan 14, 2011 | 09:46 PM
hendrixx324's Avatar
hendrixx324
I am pleased to provide vehicle build information for your 2006 Dodge
Dakota.
According to our records, your vehicle was equipped from the factory
with the following:
*C5 Cloth High-Back Bucket Seats
-D5 Med Slate Gray
AGG Sport Group
AJKS Convenience Group
AJPS Power Convenience Group
APAS Monotone Paint
A82P 4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
BAZS 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BCSS Run Down Protection Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CABP Bucket Seats
CBZS Prem Vinyl Door Trim w/Map Pocket
CFNS Rear 60/40 Folding Seat
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUCP Floor Console
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHTP Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GURS Power Mirrors
GXRP Keyless Entry
HAAS Air Conditioning
JAAS Instrument Panel
JA2S Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKWP 12V Center Console Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
KRXS STRIPE/BADGE/MOLDING/COLOR
K4RP STRIPE/BADGE/MOLDING/COLOR
K8RS STRIPE/BADGE/MOLDING COLOR
LACS Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LCDS Map/Dome Reading Lamps
LHES Rear Dome w/On/Off Switch Lamp
LMBS Halogen Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MBDP Argent Rear Bumper
MFNP Body Color Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MUMS Dakota Badge
MUZS SLT Badge
NAS 50 State Emissions
NBKS EVAP Control System
NBQP Federal Tier 2, Bin 10A Emissions
NFBS 22 Gallon Fuel Tank
NHMP Speed Control
NZDS Next Generation Engine Controller
PR4 Flame Red Clear Coat
QR4S Flame Red Clear Coat
RCDS 4 Speakers
RDDS Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TVFS P245/70R16 BSW On/Off Road Tires
TZAP Goodyear Brand Tires
WDQP 16" Steel Spare Wheel
WD1S 16X8.0 Cast Aluminum Wheels
XBSS Pickup Box
XCAS Occupant Classification System
XDXS Scissor Type Jack
XSLS Brake/Park Interlock
XVNP Basic Owner's Manual
X81S Instrument Panel Parts Module
X88S Tire & Wheel Parts Module
YAAS Build To U.S. Mkt. Specifications
ZAUP Spring - Left Rear
ZCGP Spring - Left Front
ZNUP Spring - Right Rear
ZRFP Spring - Right Front
I dont see it saying lsd? What would i look for
Old Jan 14, 2011 | 09:51 PM
Dakkkota's Avatar
Dakkkota
DRBP Corporate 9.25 LD Rear Axle LD=
locking differential
Old Jan 14, 2011 | 09:56 PM
rengnath's Avatar
rengnath
I think in my glove box it says 3.55 LSD Diff. But I didnt need to read that to figure it out. Just stand on the brakes and gun it ..... maybe use some bleach for your mudders though If you see 2 tire tracks when youre done, then you will know.
Old Jan 14, 2011 | 10:18 PM
hendrixx324
i no when i gun it or get stuck or do burnouts i spin one tire. and i thought it actualy said lsd because i no money mans sais lsd
Old Jan 14, 2011 | 10:24 PM
rengnath's Avatar
rengnath
Just googled it. The LD stands for Light Duty. Looks like you infact have an open diff.
Old Jan 14, 2011 | 10:27 PM
hendrixx324
SWEET!!! haha thanks rengnath Im ordering it tomorrow i think
Old Jan 14, 2011 | 10:40 PM
rengnath's Avatar
rengnath
No problem! Hope you like the locker!
Old Jan 14, 2011 | 10:46 PM
hendrixx324
i hope so to. ill have to send a vid of somtihn iff i can gat my hands on cheap tires ill do a sic 2 legger burnout.
Old Jan 14, 2011 | 10:49 PM
Eimer123's Avatar
Eimer123
Or just lift the rear of the truck. If the tires spin in the same direction has limited slip or locker... if they spin opposite of each other, its open. Spinning the tires is more fun!
