Thermostat Install DIY
Old Feb 7, 2011 | 10:12 PM
  #31
Altair's Avatar
Altair
Dak attack!
Excellent write up Eimer! I've copied the DIY and relevant discussion to the 3rd Gen Dakota FAQ Subsection (for anyone unfamiliar with it look at the top of this section) so it will be easy for others to find in the future.
Old Feb 7, 2011 | 10:16 PM
  #32
Eimer123's Avatar
Eimer123
thanks!
Old Feb 9, 2011 | 07:40 PM
  #33
Eimer123's Avatar
Eimer123
Originally Posted by Blown287
I'm one heat range colder than the factory plugs (6 heat range) and they have worked flawlessly. The plugs I'm running are NGK BKR7E stock# 4644.
Thanks for the info.. I just switched to these! Much better than Autolite!
Old Feb 9, 2011 | 08:41 PM
  #34
rengnath's Avatar
rengnath
I was impressed with the NGK V-Powers over the Autolites personally. Autolite just seems cheap.
Old Feb 11, 2011 | 06:58 AM
  #35
motorking's Avatar
motorking
Default spark plugs and thermostats
Originally Posted by Eimer123
I went from Autolite 5224 - Heat range D11
to Autolite 3923 or 3922 I don't recall - Heat range - D11
I hope they are 3922 the same that the HO engine runs. Something tells me I put the 3923 from the 3.7. Crap I know I should have double checked that. All I know it that I do not like them. I will know on Monday when I get to work. If they are the 3923 I will change them out to the 3922 and see if they are any better. If not I will go back to the 5224
5224, 3923 and 3922 are all the same heat range according to the web site.
Hi,
I am the tech manager at Autolite. You are going to colder and colder spark plugs heat range wise. Unless you have a blower or turbo or NOS, there is simply no reason to do this. You may even end up with cold fouling on your plugs. There is no advantage to using a colder plug on a unboosted vehicle. your engine efficiency will suffer and again, you may have a situation where it doesnt start on a cold day. Go to www.autolite.com, open the bar for tech info and watch the autolite challenge video on heat range. Same thing on the thermostats, your engine is calibrated to run best with the OE stat from a fuel efficiency and emissions standpoint, going to a colder thermostat will not help with anything.
Old Feb 11, 2011 | 08:26 AM
  #36
graythang's Avatar
graythang
Fact is even today after all these years Mopars run so much better in cooler weather. Lower T-stats and power wires go to this idea and the 4.7 & 3.7 loves to run in cool weather. I pull my power wire in cold weather and install it when it is going hang around 50 and up.
Old Mar 30, 2011 | 12:20 PM
  #37
Dakkkota's Avatar
Dakkkota
from what vehicule that 180 thermostat come from Napa in canada use different #.
Old Mar 30, 2011 | 12:27 PM
  #38
Eimer123's Avatar
Eimer123
Any 2000-2004 5.2 or 5.9 engine Dodge Dakota or Durango.
Napa Canada part#
#33508 - 180 economy series
#33008S - 180 premium series
Old Mar 30, 2011 | 12:44 PM
  #39
Dakkkota's Avatar
Dakkkota
wich one should i pick up??
whats the difference between them except price?
Old Mar 30, 2011 | 12:58 PM
  #40
Eimer123's Avatar
Eimer123
Originally Posted by Dakkkota
which one should i pick up??
I am not sure.. You will have to ask. You want one that when it fails, gets stuck in the open position. They will know what you are asking when you ask.
I am sure the premium is thicker and built with a better spring, and might have a pressure relieve section in it.
Just ask them to order both if they do not have them in stock, and only buy the one you like. The price difference is like 2 bucks between the two.
Still better than the $25usa they want for the 2005 version.
