How to adjust steering wheel
Hey everyone,
Got my struts and TM kit installed last Tuesday. They aligned it after install and said they had to correct the steering a little bit because the wheel was crooked when going down the road due to the leveling kit. Well they over-corrected it. Instead of taking it back for them to mess it up again, is there a way to do this myself? The wheel is off about 1/16th turn, which is enough to bother me. The wheels are aligned and the truck doesnt pull, its just the wheel that needs to be straightened.
The reason the 1/16th turn bothers me; going down the roads here, I normally have to keep the wheel turned about 1/16th to keep the truck going straigtht due to the bank in the roads. Its more noticable on the freeway. Depending on the lane, I have to keep the wheel slightly slanted to go straight. Now, since the wheel is 1/16th off I have to keep the wheel at 1/8th of a turn to go down the freeway in the left lane ..... and it bothers me
Thanks for any help.
Well, You could "cheat" and pull the steering wheel and move it over a tooth or two. I had to do this on an beater car as the front end was toast, and it bothered me
I bet they adjusted it with the outer tie rods, or less likely they moved the shaft that connects the steering shaft from the rack.
If it is only a tiny bit, I say move the steering wheel (it may be off anyway!)
Trending Topics
Not a big deal take it back and have them reset it. If you adjust the outer tie rods you will affect the toe in setting of the alignment. Most likely you will not be able to do it acurately with out and alignment rack. Pulling the steering wheel will work too and not affect the toe in setting.
Who did the alignment?
They are full of beans. I have heard that same line, leveling kit or not, for a very long time with this truck.
The only two places that can align my truck perfectly is my local dealership, and this one particular firestone in my area. I once had mavis try over 3 times to align my truck before they quit and gave me my money back. They could not get the steering wheel straight.
I put my own leveling kits on, and it never changed the straightness of the steering wheel. It does not change it at all.
They simply do not know how to align your truck.
