Damn electrical problems. One tail light is constantly on
Guys,
For some reason I have a tail light that wants to stay on. I have tried to replace it, but nothing changed. I ran with the bulb out and when I reinstalled it tonight, it was off. I just looked out side and it is back on. It is the passenger rear.
Any ideas?
Any ideas?
The only thing that seems logical would be if you had a 7-pin trailer harness and snow or liquid was completing the circuit between the hot wire and the tail light. This would give you the one constant on. I assume its the "brake" light that is constantly on? Is the other side functioning fine?
id check that and also i think there is a wiring diagram in the workshop manuel that you can download on this forum. And you can look at were the short could be and narrow it down to your problem.
