Remote radio switches added..almost :(
Old Feb 23, 2011 | 04:04 PM
  #21
Hey, I should get a commission on that, too!! haha...glad you got it worked out!
Old Feb 23, 2011 | 05:18 PM
  #22
Backwoods18's Avatar
Backwoods18
Wow, talk about a headache. Good Luck!
Old Mar 1, 2011 | 11:18 PM
  #23
Hammond_Egger's Avatar
Hammond_Egger
Well, had it flashed today, now I cannot adjust the volume at all Radio comes on at full volume!
I am going back in the AM to see if they just added the RDZ option or did the add and enable the radio controls....what a mess.
Old Mar 1, 2011 | 11:40 PM
  #24
KS Cowboy's Avatar
KS Cowboy
Originally Posted by Hammond_Egger
I made the appointment for Monday..1hr labor for "adding" the remote switches, programming my keyfob, and "adding" the overhead console (not needed as it worked as soon as I added it, but why not!).
Thanks to jkeaton for posting his build sheet...as that is where I got the option codes from
Will let you know the result...
How did you do the overhead console? What did you have to do to get it to work?
Old Mar 1, 2011 | 11:49 PM
  #25
Hammond_Egger
For the overhead console, it is plug and play....you will need to run 2 wires from the pass side pillar to the overhead console. Make sure you have the mounting bracket that is under the headliner...it is different from the map light console.
