Radio Swap
Old Feb 26, 2011 | 04:34 PM
08XDakota's Avatar
08XDakota
Default Radio Swap
Has anyone swapped out their standard radio for the GPS/Radio combo one? I kind of interested in doing so but im not sure how difficult it would be....
This is what I have
This is what I want
Put this on today also =D
Old Feb 26, 2011 | 04:41 PM
dakotaff's Avatar
dakotaff
That is the Mygig radio, some have swapped it out. Search Mygig radio...
Old Feb 26, 2011 | 04:45 PM
hendrixx324's Avatar
hendrixx324
does the mygig suport subs?
Old Feb 26, 2011 | 05:10 PM
dakotaff's Avatar
dakotaff
Not all of them do, not sure about the ones that are compatible with our Dakotas (low speed). I'm sure there is a way to add the sub to it though with an adapter.
Old Feb 27, 2011 | 03:33 PM
where did you get that one? Thats different from the one I have, I like yours much better!!!!!!
Old Feb 27, 2011 | 06:46 PM
08XDakota's Avatar
08XDakota
Thanks man! I got it off of decaldriveway.com, it all also came with a small dodge ram emblem that I put on the opposite corner
Old Feb 27, 2011 | 08:37 PM
Did u design it yourself or do they have that one?
Old Feb 27, 2011 | 09:00 PM
08XDakota's Avatar
08XDakota
I designed it myself, ill tell you exactly what it is when I get onto my computer
Old Feb 27, 2011 | 10:10 PM
08XDakota's Avatar
08XDakota
http://www.decaldriveway.com/decal-g...r-logos/cus128 ......the font is called dodger
Old Feb 28, 2011 | 04:01 PM
keithhud's Avatar
keithhud
I was was thinking about doing a MYGIG install. After researching several Head Units and looking at available options, I decided to installed a Jensen VM9424 Double Din.
Here is a good site for info on the different Dodge, Chrysler and Jeep radios. http://www.wkjeeps.com/MyGIG_parts.htm
There is even a link on how to remove and install a MYGIG.
One note, I have the same OEM radio you do. There is a medal support frame that the OEM radio slides into that supports the back of the radio.
Check the height on the back of the MYGIG to make sure it will slide into the medal support frame. I had to cut out the topmost part of the medal support frame to install my Jensen and this was after several sites said it would fit.
Good Luck
