Damn DIFF!!!
Old Mar 4, 2011 | 09:38 PM
Fitz-C's Avatar
Fitz-C
the solution i came to was to drill the front mount all the way through, then use two grade 8 bolt with a locking washer. for the driver side lower side that didn't line up use a ratchet to pull it forward on the diff a bit and bolted right up. the passenger side lined right up with those two in. the forward mount was bent ever so slightly that you couldn't see it. was thinking about changing the mount but looks like a PITA because it shares a bolt with one of the engine mounts. Thanks ever so much for the help guys. and Backwoods i was just about to fire up the torch before i read your message
Old Mar 5, 2011 | 05:24 AM
Backwoods18's Avatar
Backwoods18
Haha No problem. Figured I would say something just in case. Didn't want to see you get it mounted and then your mount(s) break. that would suck...
