Damn DIFF!!!
Old Mar 3, 2011 | 08:06 PM
Fitz-C's Avatar
Fitz-C
Default Damn DIFF!!!
so trying to mount my front diff up and the mounts wont line up properly? anyone have any tips!!?!? the lower ones closest to the driveshaft are too far back, and the ones on the upper driver side cant get em to thread, even tho they look lined up. this really has my stumped. The only ones that went in fine were the ones on the passenger side.
anyone have a FSM for an 05!?!?
Old Mar 3, 2011 | 08:08 PM
hendrixx324's Avatar
hendrixx324
theres one on the forum as a sticky unless that didnt help ya
Old Mar 3, 2011 | 08:41 PM
Blown287's Avatar
Blown287
Try two jacks. Place one directly underneath the differential and the other under the front of the differential where the drive shaft enter. Slowly alternate between them until it lines up.
I ran into this same problem when I did my drop shackles. Good luck man.
Old Mar 3, 2011 | 08:50 PM
rengnath's Avatar
rengnath
Are you sure the mounts didnt bend when the diff cracked?
Old Mar 3, 2011 | 09:22 PM
Fitz-C's Avatar
Fitz-C
these lower ones still need almost a quarter inch to line up
and if i thread this one the ones on the other side dont line up
Old Mar 3, 2011 | 10:01 PM
Fitz-C's Avatar
Fitz-C
there is only one front axle for the 4x4 dak the C205F? no?
Old Mar 3, 2011 | 10:21 PM
rengnath's Avatar
rengnath
Can you tell if everything is aligned under there? If there was enough torque to grenade the diff, Im guessing theres a chance that it torqued the mounting points. I cant tell from the pics how it is mounted though.
Old Mar 3, 2011 | 10:47 PM
Blown287's Avatar
Blown287
My bad man, I saw Diff thought you were talking about your rear diff. I didn't realize you were referring to the transfer case.
Old Mar 4, 2011 | 12:55 AM
bruno426's Avatar
bruno426
Not transfer case, front differential.
Old Mar 4, 2011 | 06:58 AM
Backwoods18's Avatar
Backwoods18
As stated above. The torque that gernaded your diff probably twisted your mounts. As far as advice, DON'T heat them up and try to move them. The heat will change the temper of the steel and probably make them break under load.
