aftermarket sterio
Old Mar 3, 2011 | 09:13 PM
tj.reid's Avatar
tj.reid
Default aftermarket sterio
hi there ive been looking around and havent really found anything that im looking for
i was in at best buy buying a new deck for my 2005 dakota st and they said i need a C2R-CHY4 wire harness because of the radio is part of the computer.
that part is 200bucks and the regular harness is available as well and lot cheaper
but anyways im gonna go back in tomorrow im hoping someone sees this tonight with some info on this
thanks
Old Mar 3, 2011 | 09:31 PM
Fitz-C's Avatar
Fitz-C
what there talking about is a lead to turn on the radio because the radio uses the can bus system. what most guys do is just run the lead to a 12v source such as a cigarette lighter .
For about 100 more you can go with the mygig system. Ordered mines but havent got a chance to put it in yet but most guys say its a good upgrade, and gives a clean factory look
Fitz-C's Avatar
Fitz-C
Old Mar 3, 2011 | 09:47 PM
tj.reid's Avatar
tj.reid
thats sweet i quess ebay is gonna be the best spot to get that and does it have preout for amps and subs and does it hook right up
and if i got with the cheap harness its all good other then i have to run a 12volt wire to power. in as best buy they were saying that the airbags can go off and other crazy things lol
Old Mar 3, 2011 | 09:59 PM
Fitz-C's Avatar
Fitz-C
thats where it gets tricky for the preouts you'll need a lockpick and there roughly $200. but with the lockpick you'll be able to watch dvd in motion.
nope your just tap red into the cig lighter, orange/white dimmer to red acc out of radio.
i dont really see how tapping into your cigarette lighter will make the airbags go off. cheers for now
Old Mar 3, 2011 | 10:05 PM
what is the lockpick? so normally you cant watch a dvd while your moving, but a lockpick "unlocks" that feature? Thats all the lockpick does? I'm looking at these mygigs, but I want to get everything I need at once....
Old Mar 3, 2011 | 10:18 PM
Fitz-C's Avatar
Fitz-C
it allows for dvd in motion and allows you to change nav address in motion, also has optional input/output cable you can add a backup cam. Also allows you video and stereo output AND input. and allows you to add the mic for voice recognition on nav radios
Old Mar 3, 2011 | 10:29 PM
tj.reid's Avatar
tj.reid
you guys might know is there a way to put 6x9s in the truck doors or is it stuck to the 61/2s in it
Old Mar 3, 2011 | 10:42 PM
only way I know is with a jigsaw.
Old Mar 4, 2011 | 11:46 PM
Fitz-C's Avatar
Fitz-C
so i have some updated info for you, looks like i was wrong before and for the 05-07 you WILL need the lockpick connector as the harness is not the same. Just tried it
