disable DRL ?
Old Mar 13, 2011 | 12:03 AM
ReturnToSender's Avatar
ReturnToSender
[quote= I can be a bit more detailed and even draw up a rough and dirty schematic[/quote]
I would like to see the schematic.
Old Mar 13, 2011 | 01:09 AM
Ueland's Avatar
Ueland
Ok, here's the basics of the pinouts on a relay... with a description underneath. This is the quick and dirty of it and how to make it work.
30 is the Battery
87a is Not Used
87 is the HID Low Beams
85 is Factory Low Beam/DRL from Headlight Connector
86 is connected to Ground
Relays are very simple to use once you learn how to wire them.
If you buy any sort of "kit" for the DRL's or a "headlight brightener" kit, this is exactly what your getting, just in a pretty package at 10 times the price.
Old Mar 14, 2011 | 03:37 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Simpler than an F16, eh Ueland?
Old Mar 14, 2011 | 05:44 PM
Ueland's Avatar
Ueland
Much simpler....
