disable DRL ?
I "THINK" your kinda stuck being a Canadian truck. I thought those were required up there. I wanna say its a computer setting, but I doubt the dealer would disable it since that would make your truck illegal and the mountme's would come and get you.
Hopefully another Canukian can shed some better light on it for ya...
DRL uses less power than full on. Since HIDs need the full power to the ballast they flicker instead. There might be a way to adjust the power to the DRL mode without disabling it..
Ya no dealer will ever turn off the DRLs because your Canadian (I have the same problem with my hids too)
There is a few things you can try
A DRL module
http://www.v-leds.com/Exterior-LED/D...-p6297704.html
Go to a place that installs HIDs and see how they deal with DRLs,
Or do what i do and put the parking brake on till you see the light come on in the dash, that will turn off the DRLs also,
A DRL module
A DRL module
A DRL module
Will the module work on our trucks? and would that not engage the brake even if you like just press it?
no he means just enough to turn the light on the dash on so it "thinks" the ebrake is engaged. If yours is anything like mine, I have a mile of travel in my ebrake before the brake actually engages so it should not do any harm.
Trending Topics
^^^ Exactly The only down fall to this method is the "DING" your truck telling you your EBrake is on but it only happens when you come to a stop. Drive-thrus are the worst LOL
For the module, it should work the only problem i see is the amp output of the module is only 500mA.
The ballast needs a certain amount of amps to ignite the bulbs and 500mA sounds low,
Module specs:
Input Voltage: 3V-14.5V,
Output: 14.5V/500mA
Module specs:
Output: 14.5V/500mA
[quote=jkeaton;2444949If yours is anything like mine, I have a mile of travel in my ebrake before the brake actually engages so it should not do any harm.[/quote]
My e-brake actually barely works. It will not the hold the truck while idleing in drive..
Instead of pissing off your truck (and yourself) with an e-brake light on the dash, you can easily add an inline relay that will fix the problem.
Build a headlight Relay system
Go get 2 relays
http://www.parts-express.com/pe/show...number=330-073
and 2 relay sockets
http://www.parts-express.com/pe/show...number=330-075
You'll also need:
Red 14 gauge power wire. (usually comes on a roll of 20ft)
Heat shrink tubing
Electrical tape
Butt connectors and some rings for the battery and ground
Although you "can" use the connectors, I'd really recomend soldering your connections as it is for your headlights, and failure while driving could be very bad...
Total cost for all parts should be under 25 bucks.
The relay will make your DRL's burn like regular headlights. As for the regular low beams, they "should" stay unaffected, but may actually be brighter as they will now be fed directly from the battery. (however being HID I doubt it will have any effect on the brightness.
if you need more explanation or assistance, I can be a bit more detailed and even draw up a rough and dirty schematic
Go get 2 relays
and 2 relay sockets
You'll also need:
Heat shrink tubing
Electrical tape
