high pitch squeal
Old Mar 26, 2011 | 08:14 PM
themoneyshot's Avatar
themoneyshot
Default high pitch squeal
when driving i get an high pitched squeal at the front right wheel. it is not constant and will come and go. it sounds like a brake squeal, but i can apply the brakes and it remains. it is more likely to go away when reduce the throttle. i figure if it where the brakes it would go away with pressure. the brakes have been up graded with slotted and drilled discs and ebc green stuff pads.
i have replaced the wheel bearing and cv. could these be the cause?
Old Mar 26, 2011 | 08:33 PM
FrenicX's Avatar
FrenicX
Is it under acceleration, decceleration, or both?
Old Mar 27, 2011 | 07:35 AM
themoneyshot
almost always under slight accelarartion. usually if if let the throttle up the noise goes away. if i give it gasw and hold the brake it will still make it. what you think?
