HO motor has arrived!! *pics*
Old Mar 30, 2011 | 07:42 PM
Hammond_Egger's Avatar
Hammond_Egger
Hmm, is this a used pull, or a rebuild? Why do those heads look "newer" than the rest? Where is the harmonic balancer?
Just being overly critical to point it out, not to bust your stones (you had enough of that already!)
Old Mar 30, 2011 | 07:48 PM
thunder98110's Avatar
thunder98110
it was a pulled motor with ~67k miles. yeah the heads do look new, i dunno why. not sure where the crank pully is but i assume i can use mine.
Old Mar 30, 2011 | 08:38 PM
thunder98110
im going to check on the VC bolt. the motor is not with me but at a friends shop so I gotta wait till he can do it.
Old Mar 30, 2011 | 09:52 PM
thunder98110
thank you all. im sure its just not bolted all the way. but now i just need to get it installed.
Old Mar 30, 2011 | 09:57 PM
Dakkkota's Avatar
Dakkkota
good luck
maybe those heads were send by the original ownwer for a radicall head porting job..you never know!!!
:P might be something positive :P
Old Mar 30, 2011 | 10:21 PM
Hammond_Egger
Dude, I am pretty sure the balancers are different from the non HO to the HO motors..
I would seriously check it over well...they may have just slapped HO heads on a non-HO motor...Make sure it has HO cams as well.
After all you have been through, do the legwork BEFORE putting in in your truck!
Old Mar 30, 2011 | 10:40 PM
thunder98110
I asked richie if there is a difference. we will see.
Old Mar 30, 2011 | 10:47 PM
thunder98110
rock auto lists the parts as the same between the jeep ho and my 01. its only 36 bucks so if i need one no biggie.
