Just finished Efan conversion
Old 04-20-2011, 10:02 PM
Jetster220's Avatar
Jetster220
Jetster220 is offline
Originally Posted by damyankee84
What controller did you use?
This one, http://www.a1electric.com/Merchant2/...ode=FAN-PWM-V3
  #32
Old 04-20-2011, 10:46 PM
Ueland's Avatar
Ueland
Ueland is offline
Originally Posted by Jetster220
My truck doesnt have heated seats though?
Neither does mine, but the connection is still there in the fuse box
  #33
Old 04-20-2011, 10:51 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
show us how you did ueland!!!!!
pick in fuse box!!
  #34
Old 04-20-2011, 11:45 PM
Jetster220's Avatar
Jetster220
Yes and Dakkkota said, and are you referring to the fuse box under the hood, or in the cab?
  #35
Old 04-21-2011, 07:08 PM
Hammond_Egger's Avatar
Hammond_Egger
Hammond_Egger is offline
Hmm...I have a 20a fuse in #58 (Heated seats)...but do not have heated seats!
I looked in the service manual, only circuit I see for the #58 fuse is heated seats!
Anyone else have a fuse in the #58 slot?
  #36
Old 04-21-2011, 08:46 PM
sullysdetailing's Avatar
sullysdetailing
sullysdetailing is offline
Did you notice any improvement in power, gas mileage, or throttle response
  #37
Old 04-21-2011, 08:53 PM
Ueland's Avatar
Ueland
Ueland is offline
pick in fuse box!!
Yes its the fuse box under the hood, as for connecting, I used a fuse tap, but its just as easy to make a lil loop in the wire and slip it around the leg of the fuse.
These are the fuse taps I used.
http://www.clipsandfasteners.com/Min...p_p/a17686.htm
The bad news is they only come in a box of 50. The good news is they're cheap. ($7.00) So I've still got about 47 of em left.
If you wanna do the twisty wire thing as a temporary connection, I could probably send you some, just know that it won't be that quick as I'm in the process of moving.
Here's a brand new pic of the fuse box...
Hope that helps with where to run the wires. also for the A/C turn on it goes to pin#87 on the relay. you can also use the mini fuse taps for that too, but I think I had to trim a bit of the relay slot itself cause it has "corners" that interfere with the wire. (it'll make sence when you look at it)
  #38
Old 04-22-2011, 12:00 AM
Jetster220's Avatar
Jetster220
Thanks Ueland! Thats awesome dude, exactly what I was looking for.
  #39
Old 04-22-2011, 08:20 AM
Hammond_Egger
Ueland,
What size fuse did you use for the fan? Did you run a fuse for the trigger voltage?
I still cannot figure out why we have a 20A fuse populated if we do not have heated seats!
Makes no sense....
  #40
Old 04-22-2011, 08:27 AM
Ueland's Avatar
Ueland
Ueland is offline
Ueland,
Makes no sense....
I used the fuse that was there (20a) if you hook to the same side of the fuse that I did its the "cold" side of the fuse, so the fuse in the box would be plenty sufficient for the fan controller. Remeber this is a trigger wire and NOT a power wire, so it could probably use a fuse as small as 5a without any issue.
Quick Reply: Just finished Efan conversion
