2.5 inch Leveling kit installed in 3 hours
Old Apr 12, 2011 | 04:16 PM
cheeseburger's Avatar
cheeseburger
Default 2.5 inch Leveling kit installed in 3 hours
because im that awesome
check it out
wasnt even that hard and i save 265 dollars on labor. it took two guys but it was easier than i expected. im a little worried about the tie rod ends but im prepared to replace them if they tear up. everything else went together nice. i am gonna have the alignment checked before i drive it very much though. it feel like it goes down the road great but idk if its within spec of not. we will see.
Old Apr 12, 2011 | 11:03 PM
Sdowdle541's Avatar
Sdowdle541
Looks good. I need to get off my butt and do mine.
Old Apr 12, 2011 | 11:09 PM
ive got a 2.5" kit that comes with 1.5" blocks in the back coming by the end of the month.
Old Apr 12, 2011 | 11:11 PM
cheeseburger
good luck. let me know if u need help putting it in i can give advice.
Old Apr 12, 2011 | 11:25 PM
rengnath's Avatar
rengnath
Time for some bigger tires! Looks sweet though. I like it better than the lowered look.
Old Apr 12, 2011 | 11:36 PM
cheeseburger
ill get the bigger tires when i have the $$$$ and when i do im gonna put 2 inch blocks in the back.
Old Apr 13, 2011 | 10:25 AM
dodgedad80's Avatar
dodgedad80
Make sure to get it aligned. I put 2" on mine and an alignment was need. Looks good!
Old Apr 13, 2011 | 11:02 AM
rengnath's Avatar
rengnath
Also, make sure you take it to the dealer to get it aligned if possible. You can try local shops, but I know a few others including myself have had trouble with them actually getting the alignment right. I took mine to the dealer after my shop tried aligning it and the dealer said the toe was way off. It was worth the $60 at the dealer; now my alignment is dead on.
