Burned Up Planetary Gears
Old Apr 14, 2011 | 12:14 AM
Blown287's Avatar
Blown287
Default Burned Up Planetary Gears
As many of you know I built up a new 545-RFE transmission and installed it a couple of weeks back. Last Saturday I started taking my old transmission apart to ..........
1. See how it handled 100k of abuse and
2. Maybe rebuild it and sell it.
I found my planetary gears (for 3rd) were burned up. Burned to the point the clutch surface is completely gone.
Old Apr 14, 2011 | 05:05 AM
Backwoods18's Avatar
Backwoods18
Wow, I have never seen that. I will say that I'm glad you pulled it when you did
Old Apr 14, 2011 | 09:52 AM
Blown287's Avatar
Blown287
About every six months I would throw a P0700 code and it would go into limp mode. I would change the transmission filters and fluid and it would go away. With what I know now, I think the clutch material was breaking loose and cogging up the tranny filters. It would loose pressure and go to limp mode.
This explains why my 3rd gear pull sucked.
This explains why I only pulled down 308 rwhp on the last dyno.
Old Apr 14, 2011 | 09:54 AM
Blown287's Avatar
Blown287
I have completely gone through the rest of the tranny and can't find anything else wrong with it. The rest of it looks really good.
Old Apr 14, 2011 | 12:44 PM
rengnath's Avatar
rengnath
Wow, good thing you pulled it. Were you experiencing any noticable slipping or revving RPMs?
Old Apr 14, 2011 | 12:57 PM
Blown287's Avatar
Blown287
Nope, I would throw the P0700 code, go into limp mode and change the fluid/filter and it would go away. This would happen about every six months or so.
Marty from the Old KRC watched my dyno vidoes and reviewed my logs from last December and he was the first to suggest it was slipping.
http://www.bionicdodge.com/bionic/in...?topic=11114.0
I didn't feel the slipping but that is when I bought the new transmission and started building it up just in case (glad I did). I even bought a new Edge stall converter and send my old one back for a cut and clean. So I have two of them now, lol.
Hopefully the new injectors will be here today or tomorrow because I have to make a 3rd gear pull video for you guys. It's stupid fast compared to the old transmission.
Old Apr 14, 2011 | 01:05 PM
rengnath's Avatar
rengnath
So was swapping to the 3.55s still the way to go?
Old Apr 14, 2011 | 01:08 PM
Blown287's Avatar
Blown287
For my 3rd gear pull, yes. I'm hitting max boost in 3rd gear, I've never done that before. If I can get everything done I want to hit the dyno next week before I leave for school in RI. Once tuning is done, back to the track.
Old Apr 14, 2011 | 11:43 PM
hendrixx324's Avatar
hendrixx324
i cant wait
Old Apr 14, 2011 | 11:52 PM
Blown287's Avatar
Blown287
That makes two of us. If my injectors get here tomorrow or Saturday I will have to make some WOT videos to send to Hemifever for tuning. I will post a couple of them up when I do. Just hope this rain stops so I have some dry pavement
Plus I need to get a good test of the new Auburn LSD also.
