Help! water leaking in!
Old May 4, 2011 | 04:51 PM
dakota_raven's Avatar
dakota_raven
My 2007 was doing the same thing and it turned out to be a bad windshield seal. Fixed by the dealer under warranty!!!
Old May 18, 2011 | 09:49 PM
Blackheart4355's Avatar
Blackheart4355
My truck did this when I first got it, but it has no sunroof...it did it once..took it to the dealer and they couldn't get it to repeat...never happened again...
Old May 18, 2011 | 10:09 PM
Altair's Avatar
Altair
Dak attack!
Given you have the sunroof I'd try blowing out the drain tubes first but when diagnosing water leaks the friend with a hose and you inside with a flashlight method is tried and true.
Old Jul 24, 2012 | 07:48 AM
gunner44's Avatar
gunner44
Default Leaking Dodge Ram
I have a leak after rains that enters into the cab from the overhead mounted TV. I assume the rear drain tubes are plugged...anyone able to tell me where i can find these tubes so I can clean them?
Old May 14, 2013 | 09:52 PM
prp9391's Avatar
prp9391
Great info as I am seeing the same leaks in my 07 quad 3500 after the heavy rains here in Seattle, both columns drip out of the bolt holes on the seats and the carpet. I have the sun roof and will start with the drain holes and go from there...
Old May 22, 2013 | 04:34 PM
ajb1203's Avatar
ajb1203
Originally Posted by jettcity1
I have an '08 Laramie with a factory sunroof and after 40,000 miles, it is leaking. It looks like it is coming in and leaking inside the windshield pillars and dripping from the grab handle on the window posts, both sides. Water is also dripping onto the right side floormat from the lower dash area.I assume it is from the sunrrof although it could be the windshield, either way the warrantee is up and the dealer wont fix it (go figure) Has anyone had this problem and what would be the first step? I have opened the sunroof and cleaned the edges and looked for debris, it appears to be clean. This is obviously rainwater and not condensation. let me know what my options are before i contact a specialist and start disassembling this thing.
I have had the same leaks on my 08 Dakota Laramie with sunroof. It leaks on both sides, leaking through the top bolt in the handle trim piece. This week a new leak with water dripping out from the bottom of the overhead compass/temp display. (I have no clue where the leak is coming from) Does anyone know where the drain tubes for the sun roof drain too?
Old May 26, 2013 | 09:07 AM
Rocky4052's Avatar
Rocky4052
I had the same problem. The drain tubes are in the front door jams in between the hinges. You will see the hoses sticking out. If you drop the headliner down on both sides,(drivers and passenger side) you will find the hoses. Disconnect them, and blow out with air. Make sure the tracks are clean, also. It worked for me.....................
