How much CV Joint play is acceptable?
I think I've narrowed my front end noise to both front half shafts. When turning at low speeds i can hear a squeak or chirping noise. Turning in both directions that is. While doing my oil change today i put my hand on each half shaft between the two rubber boots and there was play moving left and right toward and away from the wheel. There was no play up and down toward and away from the ground. Is play left and right (or in and out) acceptable, and if so how much? Should I let my lifetime powertrain warranty go to work on this one?
Thanks guys!
Thanks guys!
Yes, it seems to be in and out play from both joints on the shaft. If you put your hand on the small part of the shaft between the two boots it goes in and out in both directions and clicks. When driving its a squeaking or chirping sound though, not a clicking noise.
Trending Topics
Replace the joints. The inboard joint is supposed to have in and out play to allow for suspension movement. The outer jount is supposed to be fixed.
do you have any vibrations? i ask because i thought mine was from the axle. i replaced it but still had the clicking/chirping/vibration...took it to a shop and they could not find it...i loosened up the rear driveshaft the other night at the pinion and moved it around a bit, now I dont have the chirping but I still have the clicking every now and then and the vibration has almost gone away. I wondering it a u-joint could fail in these trucks without coming apart, i.e. lose all the lubrication, squeal, chirp, etc, but still hold together...with no outward signs that it has failed because thats where i've narrowed mine down to....
Yes, I have a vibration at about 50+ mph that is what provoked me to get underneath and try to find the problem(s). The whole truck shakes, I can't tell which end it is really coming from. I thought I threw a wheel weight but they are all still on.
