Upper control arms pictues!!!3,5'' lift kit!!!
its a 2wd!!!
lol i am sure the 71111 monroe 2006 1500 ram quick strut + this upper+ 934 CV JOINTS+flipped tie rod would work good the only negative side is the upper is not ajustable look at the negative camber!
couple things i see wrong...
props on him taking the leap and buying it though. all that work and money for 3.5"?
- Tie rod is almost at its max potential at ride height...doesnt allow for much droop travel
- im sure the airbagit coilover is made with some "quality" materials and good long lasting seals
- non adjustable upper= nasty camber
- balljoint upper....still only allows for about 12* of flex
- the rear facing tube on the control arm is bent....that is just asking to be bent even more during abuse. the rear tube on these arms should always be straight
JUST SHOWING :P
but total chaos and camburg are non ajustable uppers
