Black Cat Custom Gauge Face Installed !!!!
Old May 1, 2011 | 09:01 PM
ReturnToSender's Avatar
ReturnToSender
Thumbs up Black Cat Custom Gauge Face Installed !!!!
Just finished up the install
The whole process went fairly smooth. I did run into a snag on the modification of the needles but ill explain that at the end.
And also one more thing in the instructions it rambles on about taking the vehicle to the highway and documenting the location of the needles at certain RPMs and speeds so you can put them back on in the correct location for them to be accurate after the install , Instead what i did was with the ignition in the off position hold down the trip/odometer button and turn the key to the on position.
This puts the cluster into the sweep mode (as seen in the video below) then i used that vid to put the needles back in the correct places
All in all that was the hardest part putting the needles back on very tedious and time consuming
Anyway here's some pictures
Needle sweep video
Now the snag with the needles.
This new face eliminates the factory needle stoppers so the needles need modification, I did it exactly as in the instructions and could not get the any of the needles to do a full sweep or sit at zero as a result this is what i had to do to make it work
I'm going to contact Black Cat with this problem, in the mean time before you start your install make sure you have a small file to shave down that red nub on the back of the needle if needed .
Old May 1, 2011 | 09:07 PM
your links dont work
Old May 1, 2011 | 09:08 PM
ReturnToSender
Fixed
Old May 1, 2011 | 09:16 PM
cool. so then the red "nub" becomes the needle stop?
Old May 1, 2011 | 10:10 PM
ReturnToSender
Yes that's right
Old May 1, 2011 | 10:15 PM
dakotaff's Avatar
dakotaff
Very nice, I'm going to be installing mine later this week. The instructions say to file down the cylinder mold, but leave a small section intact the same width of the red block. It looks like you filed down the whole cylinder mold and did not leave that small section by the red block. Or did you file that section out later?
And what tape did you use to hold the tabs. They mention celo tape, what the hell is celo tape.
Old May 1, 2011 | 10:40 PM
cellophane tape maybe??
Old May 1, 2011 | 11:13 PM
ReturnToSender
Ya that's the kicker i did that originally and it didn't work i tried everything
including moving the face around i spent 3 hrs trying to figure it out and thats what i had to resort to its all most like the faces are cut wrong where the needle stops at. That red nub interferes with the sweep of the needles
Like i said im going to email Black Cat with this post hopefully they can shed some light on what i did wrong.
Old May 1, 2011 | 11:22 PM
dakotaff's Avatar
dakotaff
Ok, post up their response, I would like to hear their reply.
Old May 1, 2011 | 11:49 PM
ReturnToSender
OK emailed them hopefully they will post up a response
I got a few night shots
