Old Aug 10, 2015, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
Transmission Fluid and Filter change questions...
Old May 9, 2011 | 02:17 PM
GrnDak01's Avatar
GrnDak01
Originally Posted by Blown287
6qts if you just drop the pan. 14 qts is you drain the cooler, lines and drop the tranny/pull the torque converter and drain it.
Blown or anyone in the know I've got a ?. I want to drop the pan (which will be easy enough) and replace filters. Your comment got me thinking if I could drain the lines that will allow me to replace that much more fluid. Is it as simple as disconnecting the lines? Or will I need to put on some pressure? Plus if I pressure the fluid out will I need to do the reverse to get fluid back in? I'm just wondering if its okay to have some air in the line till the tranny itself gets all the air out. I ask because I heard once that transmissions can suffer damage to some bearings if they are starved of fluid. Thanks for any info.
Old May 10, 2011 | 09:02 AM
GrnDak01's Avatar
GrnDak01
I found a write up by Popular Mechanics that says you can pull one of the lines on the cooler and run the engine to pump/drain itself out. Sounds interesting and cheaper than taking it to a shop. But I know the shop can pressure flush while this is not a true pressure flush. Any how I'll give this some thought.
http://www.popularmechanics.com/cars...enance/1272521
Old May 10, 2011 | 01:00 PM
rengnath's Avatar
rengnath
Thats how the trans shop flushes my trans. They use the pump in the tranny to exchange the fluid, that way there is no high pressure to destroy the transmission.
