Aftermarket radio install problems
Old May 4, 2011 | 08:06 PM
gush's Avatar
gush
Default Aftermarket radio install problems
I just bought an 05 dakota slt 2wd and decided to put a better radio in it. I chose to use a clarion cz501 from crutchfield and purchased the axxess retained accessory power adapter as well.
After installing the radio everything worked great with the exception of one thing: when i turn the truck on and off the radio turns on an off.. but when i turn the truck to accessory power and then off the radio stays on (even when a door is opened).
Does the 05 have retained accessory power? Should the radio be staying on when i turn off the truck untill i open the door? If so, is there some sort of fuse or circuit i can check to make sure this is working or fix it?
Crutchfield has been a great help in trying to figure this out but after they sent me a new r.a.p. unit and it didnt work as well they pretty much said i have to deal with it. They called metra and asked about this problem and we followed the steps they gave us to try and sync the box but it will not sync. They called metra back again and they were told that this truck is just difficult to get aftermarket components to work with and i have to deal with it cause its the truck that is messed up.
I tried searching the web but didnt find anything.
Any help??
Old May 4, 2011 | 08:53 PM
cheeseburger's Avatar
cheeseburger
you could just run the accessory turn on wire (red) off the back of the cigarette lighter. and then it would turn on and off with the accessory circuit. other than that no real ideas.
Old May 4, 2011 | 09:21 PM
The Dutch Touch's Avatar
The Dutch Touch
That's what I did with mine, i had the same problem. Now it works fine.
Old May 4, 2011 | 09:24 PM
MitsuRaider's Avatar
MitsuRaider
Yup I did the same thing
Old May 4, 2011 | 10:04 PM
italiandominator's Avatar
italiandominator
That still sounds pretty efffed up. I have had after market radios in several vehicles and I never had to do nothing except get the right wiring harness, from there it was just plug and play. Why the issue with our Daks? or is this more of a common thing with newer vehicles?
Old May 5, 2011 | 11:25 AM
dakota_raven's Avatar
dakota_raven
You got to remember that in our trucks everything is controlled by the pcm... It sucks but that's the way they build it!!!
Old May 5, 2011 | 05:04 PM
cheeseburger
he may be just a one post wonder and never actually return to get his answer... oh well..
Old May 5, 2011 | 05:27 PM
Moneyman19's Avatar
Moneyman19
i only installed my radio and the way it is the radio will be on when i turn it on and turn off when i want it too. yea sucks if u forget about it i did once for 5 hours but came back and turned key and trucked started. i like it cuz i can have radio on without putt my key in and hearing that ding lol.
