Driver side window not working. Help!!
Old May 11, 2011 | 04:16 PM
Backwoods18's Avatar
Backwoods18
Default Driver side window not working. Help!!
So after work I was on my way to cash my pay check. I drive a company truck so my truck was sitting all day. I hopped in the truck and went to put the windows down. Passenger goes down fine but the driver's window doesn't move. I thought it was the switch but it's not. The locks work and the switch makes a click when the driver's button is pressed but the window doesn't budge. It worked fine yesterday... any ideas??
Old May 11, 2011 | 04:22 PM
rengnath's Avatar
rengnath
Be happy it didnt get stuck in the down position? Lol
Sounds like the motor is toast, and you are hearing the relay clicking possibly. I would tear the door panel off and check the tracks of the window to be sure nothing is blocking a moving part.
Old May 11, 2011 | 04:24 PM
Backwoods18
I have tomorrow off of work so I will tear into then. If the motor is toast, could I swap the passenger and driver's side motor? Nobody rides in my truck except the wife and she never rolls the window down. "It screws my hair up!!" ugh deal with it
Old May 11, 2011 | 05:00 PM
wingman_214's Avatar
wingman_214
The only reasonable fix is a hemi swap. What a shame.
Old May 11, 2011 | 05:50 PM
Deer Hunter's Avatar
Deer Hunter
driver and passenger side motors are NOT interchangable
Old May 11, 2011 | 07:55 PM
Backwoods18
Damn!!
Old May 11, 2011 | 09:16 PM
cheeseburger's Avatar
cheeseburger
before u do anything else make sure ur motor is getting 12v and is grounded.
Old May 11, 2011 | 09:21 PM
could just be a wire or connector loose. need to take the door panel off and have a look-see....
Old May 11, 2011 | 11:25 PM
lootownpunx's Avatar
lootownpunx
im in the same boat as you woods! ill have to dig in also err
Old May 12, 2011 | 06:11 AM
Backwoods18
Thanks guys. If the weather holds off I will rip right into it.
If you find out anything before I do let me know. I hope to tear into today.
