Front end delima
Old May 12, 2011 | 10:55 PM
wingman_214's Avatar
wingman_214
When changing any suspension and especially any steering conponant its a good idea to have your alignment checked, 99% chance your going to need it.
Originally Posted by rengnath
I would drive a mini-van then .....
Ive got a caravan parked in the driveway. But shes a latina freak of nature.
Old May 12, 2011 | 11:01 PM
Originally Posted by KS Cowboy
BTW, (and i know i should just look this up, , but what typically goes wrong, and how much and how hard is it to replace any of the front end parts? Or is it better to take it to a shop and have them put it all in..
sway bar end links: A DIY job, takes 15-20 mins per side
Struts: professional shop recommended unless you have the right kind (wall mounted) spring compressor
Ball joints: uppers require replacement of entire control arm. Another DIY job, two bolts and the ball joint, your done. Lowers I believe should be replaceable? I cant remember. Some have trouble with the steering rack. Eimer can attest to the difficulty of replacing that.
Old May 12, 2011 | 11:04 PM
KS Cowboy's Avatar
KS Cowboy
Here is just a nother thought, wouldnt they have had to tear the entire front end apart when they fixed my front ring and pinion in january? So if so, id guess that they would have checked the rest of the front end for worn parts too? Right or am i just dreaming???
IF they did have to tear the truck apart, id just get the rancho's and put them bad boys on, if they had to look at the other parts at that time.
Old May 12, 2011 | 11:10 PM
wingman_214
Most professionals would have checked the entire front suspension, they get paid more. Muat have been a rich mechanic.
Eimer123's Avatar
Eimer123
The Rack is very easy to replace. The issues I had was the manufacture did not reassemble it correctly, and the mounts were off.
Old May 13, 2011 | 03:35 AM
projektdirtfab's Avatar
projektdirtfab
or go eyelet conversion plates and run a real coilover. charge the nitrogen to about 120psi and leave it alone for years to come
