Vibration Solved
Old May 12, 2011 | 11:12 PM
Originally Posted by wingman_214
Glad it cost you $20 rather than $325. Most people would have driven it until the cap was gone. I recomend you grease all the suspension, steering, and drive train parts at every oil change.
I know, I actually had an appt. for tomorrow morning at another shop to see if they could figure it out. I was figuring on spending that much...lol....and it would be great if our trucks had greasable suspension, steering and drive train parts...lol...there is not one grease fitting anywhere on these trucks unless you have replaced factory parts with aftermarket greasable ones...
Old May 13, 2011 | 12:52 AM
markbomgardner's Avatar
markbomgardner
which u joint was that?
Old May 13, 2011 | 06:36 AM
TomZ's Avatar
TomZ
Originally Posted by jkeaton
an hour of it was removing the d@mn bolts holding the flange onto the pinion. Some idiot at Dodge thought it best to put non service removable lock tight on those bolts...talk about a biotch to remove!
(Thinks a 18VDC DeWalt impact is a great investment)
Old May 13, 2011 | 06:37 AM
Backwoods18's Avatar
Backwoods18
What kind of vibration were you having? I have rebalanced my tires twice and then I get a vibration that only get worse when I step on the brake. (like a broken belt in a tire but it's not). Thought it was a wheel bearing. Nope all four are good.
Old May 13, 2011 | 09:29 AM
I have pneumatic impact, would not budge them. Had to put a 2 ft extension pipe on the socket wrench to get enough leverage to turn them. I swear it was like stainless on stainless galling...but it was just the locktite.
My vibration was under acceleration only. and when I got up to @75 mph. Terrible, shook the whole d@mn truck. It also made a terrible noise under hard acceleration, somewhere between one of those wooden turkey call sounds and birds chirping....
Old May 13, 2011 | 10:10 AM
Backwoods18
Oh ok. That's not my problem. Thanks Kent!
Old May 13, 2011 | 11:39 AM
gjmoran's Avatar
gjmoran
great job finding the problem man.
Old May 13, 2011 | 11:56 AM
rear joint on the rear driveshaft
Old May 13, 2011 | 03:10 PM
superdak05's Avatar
superdak05
may have to look into this, with the amount of abuse the truck takes, nice find
Old May 13, 2011 | 11:55 PM
Ueland's Avatar
Ueland
So what did the bearings look like under the other 2 caps.. i'm betting the cap on the right with the busted seal was in pretty bad shape too...
