Vibration Solved
Well, I knew it was a wheel bearing or a u-joint, but nothing was loose....at least the way I was checking things....shout out to Ueland for another save...I now know how to check for a bad u-joint the correct way and actually find it...if you notice the bottom joint, no bearings, no grease....thanks Michael! Drives like a new truck. Took me about 2 hours start to finish to swap the u-joint.
they way I was checking it, I had it on the ground and was using a prybar trying to pry the joint one way or another to see if it had any play. None, solid as a rock. Well, of course, it's in gear and parking brake is on, etc. of course it's going to be solid...Ueland suggested I jack the truck up, put it in neutral and then see if there is any play...waalaa....loose u-joint...
this d@mn vibration has been driving me batty for over a month.....funny thing is, I took it to Merchants Tire and Auto and they could not find anything...wanted to replace the CV axle that I had just replaced because they said it was a rebuilt one (even though it was brand new), I said ok and if that does not fix the problem? they told me, well we'll keep looking...after I paid them $325 for a new CV axle. I told them thanks but no thanks, I'll figure it out myself...
2 hrs for an install, you are getting old! The only way you are forgiven if beer was involved...glad ya got it fixed regardless.
Trending Topics
an hour of it was removing the d@mn bolts holding the flange onto the pinion. Some idiot at Dodge thought it best to put non service removable lock tight on those bolts...talk about a biotch to remove!
