not a computer geek
Old May 13, 2011 | 09:54 PM
gizmo1's Avatar
gizmo1
Red face not a computer geek
i'm old school so i don't get these codes. but ihope i can get some help with them. i have a 2005 dodge dakota 4x4 and i bought a craftsman obd1/obd2 code reader. the codes it gives me are P0004 and P0007. the truck runs fine most of the time but occasionaly when at a traffic light it stumbles like it's gona shut off. please help if you can and thanks
Old May 14, 2011 | 08:46 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the third generation dakota section,
FF
Old May 14, 2011 | 09:45 AM
I'm on my phone but if you Google obd codes you can find those codes. Welcome to the forumm by the way. As far as the stumbling goes, if you just bought it I would recommend a tune up, new plugs, air filter, oil/filter change. Also, the IAC (idle air control) can get dirty and result in uneven idle. You can remove and clean it, also clean the throttlebody while your in there.
Last edited by jkeaton; May 14, 2011 at 02:25 PM. Reason: added info after i got to a computer
Old May 14, 2011 | 06:47 PM
gizmo1's Avatar
gizmo1
Thanks jkeaton for the help i'll tell you a little more of the saga i went to advance auto they looked the code definitions up and didn't have a clue.they could'nt find a listing for a fuel pressure regulator. I went to auto zone ,they put there code reader on the vehicle and got no codes asked me if i cleared them and of course i had not,went to a small independent auto supply store and they had not a clue,they told me to take it to the dealer. i took it to the dodge dealer in the first place they put it on there machine and told me it needed an oil change,tune up and new front brakes which i took care of. this of course did not fix the problem.No wonder folks get so frustrated
Old May 14, 2011 | 09:25 PM
Eimer123's Avatar
Eimer123
Those are just generic codes. Could have came up when your truck engine stuttered. I would pull the air intake and see how clean the sensors look. Also check the battery terminals, and of coarse clear the codes and if they come back dig into it more.
Old May 14, 2011 | 10:17 PM
gizmo1's Avatar
gizmo1
ericemery they did clear them and they came back. and eimer123 i will try that also thanks for the suggestions
Old May 15, 2011 | 09:28 AM
Backwoods18's Avatar
Backwoods18
Welcome aboard!
Old May 17, 2011 | 11:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
