radio signal weak
Old May 26, 2011 | 04:50 PM
ODXBeef's Avatar
ODXBeef
I know quality digital ballasts would take care of the issue for good, but I believe that a relay kit would at the very least mitigate the issue.
The reason I say that is my hella 700's are converted over to 55 watt HID's with ddm's cheap raptor ballasts, but they are run off a relay and I get no noticeable feedback or noise through my stereo,
Old May 26, 2011 | 11:33 PM
kbond's Avatar
kbond
this is strange because my headlights are powered by a relay and i have feedback when theyre on.
Old May 27, 2011 | 08:14 PM
ODXBeef's Avatar
ODXBeef
Then I guess it is all in the ballasts and the fact my hella's are drawing power straight from a seperate relay harness that is only activated by the high beam circuit they won't feedback regardless.
My fog's are ddm's digital ballasts and they seem to be noise free.
Old Feb 10, 2020 | 03:39 PM
James Richardson III's Avatar
Default Poor re
Originally Posted by Brand
I just Googled "RF interference from HID lights" and got thousands of hits.
Most seem to suggest that the problem originates with inexpensive/poor quality ballasts.
I get the impression that you can do all sorts of things to try to FILTER that noise, boost the radio signal, ground the radio better, etc.
OR, and what I would do if it were me, you can try to eliminate the problem at the source with a better-designed ballast in the first place.
Add ferite caps ( little blk cylinders enclosed in plastic like on your home tv or pc monitor) to power wire of hid ballast and oem harness headlight wires...you can purchase from ebay i think like 7 of them for around $12 or if u have bad tv or pc monitor pop it off and put power wire in center & zip tie..it will correct ****..-car audio / fabricator 20+ yrs
Old Mar 10, 2020 | 04:51 PM
David Kalinowski's Avatar
David Kalinowski
put the ballasts in a lead lined box It should work in theory lol. might overheat though.
