radio signal weak
Old May 24, 2011 | 11:11 AM
kbond's Avatar
kbond
Default radio signal weak
anyone know of a way or part to boost your fm radio signal? after installing my hid's in my headlights and foglights, there is lots of interference. anyone experience this or know of a way to minimize this?
Old May 24, 2011 | 12:07 PM
Brand's Avatar
Brand
I just Googled "RF interference from HID lights" and got thousands of hits.
Most seem to suggest that the problem originates with inexpensive/poor quality ballasts.
I get the impression that you can do all sorts of things to try to FILTER that noise, boost the radio signal, ground the radio better, etc.
OR, and what I would do if it were me, you can try to eliminate the problem at the source with a better-designed ballast in the first place.
Old May 24, 2011 | 02:43 PM
is your radio stock or aftermarket? If aftermarket I would go and check to make sure you have a good ground(s). also make sure the HID system is well grounded. hmm...i'm getting ready to install HID's...guess I better start googling myself....wonder if you could wrap the ballasts in aluminum (or tin?) foil to test if it's the ballasts...
Old May 24, 2011 | 02:49 PM
kbond's Avatar
kbond
its the stock radio. im going to try wrapping each ballast in tin foil, and then if i can get my hands on it, copper wire. i read somewhere today that it helps block out RF signals.
Old May 24, 2011 | 03:02 PM
Eimer123's Avatar
Eimer123
Good luck finding actual tin foil, all has been changed to aluminum, and that will do nothing. Copper sheeting might do a little, but its just coming the problem
Old May 24, 2011 | 04:02 PM
rengnath's Avatar
rengnath
If you arent running relays yet, that has been suggested before to fix the interferance problem.
Old May 24, 2011 | 05:04 PM
Backwoods18's Avatar
Backwoods18
I heard this also
Old May 24, 2011 | 05:14 PM
crap, now I gotta get relays too?? sounds like the government is involved in this...lol
Old May 24, 2011 | 05:18 PM
Brand's Avatar
Brand
Like I said: You can stand on your head & try all sorts of things to filter/mask/reduce the RF noise being generated by the cheap ballast . . . OR, you can just get a non-noisy ballast in the first place.
Old May 26, 2011 | 04:28 PM
MitsuRaider's Avatar
MitsuRaider
My radio signal got VERY static a couple of days ago. Plus my car would take longer turn over. Got a new battery and that was the end of that.
The reason why I brought this up is because I never knew low voltage on a battery would cause bad reception.
