just a question, whats the HID bulb code for 08 and up dakotas? i dont want to get the wrong ones. and we have the hi/low all in one bulb right? and whats the code for fog lights as well
Here ya go just type in your year and truck type and it will give every single light code you need.
I got this through v-leds.com it's where I got my HIDs and LEDs.
8000k is still VERY bright, and i often get flashed even with my headlights and foglights pointed correctly.
Also odx is correct in saying you need a relay for your high/lows or else they will flicker really bad, and the foglights do not require a relay, as they will work just fine without it.
Do HID kits come with the relay harness, or is that something I would have to buy separately?
Most kits come with everything you would need for the install, but it would be better to contact your retailer to make sure.
Save yourself some time and headache and double check. Trust me, been there done that.
Thank you much, Dutch!
So I wanted to know if anyone has the 55w blasts and bulbs for their headlights. I know that they run quite a bit hotter and they are really not recommended for the fog lights just because the housing is soo small. Opinions anyone?
