Lifter noise
Old Jun 3, 2011 | 09:55 PM
I recently noticed a different noise from my motor...a ticking when I first start it, before it warms up...I switched to synthetic ( mobile1)
Old Jun 4, 2011 | 02:39 AM
hendrixx324's Avatar
hendrixx324
Phil did it happen to be synthetic oil you used before and non synthetic now?
Old Jun 4, 2011 | 06:52 AM
phil74501's Avatar
phil74501
No. Just regular Quaker state oil. Would I be better off going to synthetic oil?
Old Jun 6, 2011 | 12:22 AM
hendrixx324
well i just said that because it can be bad to go back to conventional motor oil if you were using synthetic before
Old Jun 6, 2011 | 02:41 PM
graythang's Avatar
graythang
Not lifters, valve lash adjusters.
Old Jun 9, 2011 | 01:28 PM
mprohr's Avatar
mprohr
Valve Lash Adjuster noise is very normal. And more noticeable with the lighter weight oil (that you should be using anyway). Dodge recommends 5w-20.
Old Jun 9, 2011 | 02:00 PM
JayDak05's Avatar
JayDak05
From: Effort, Pennsylvania/Goldsboro, North Carolina
Valve Lash Adjusters seem to be a common thing in our engines. I know mine have been making noise and I'm using 5W20. I thought it was my valve springs at first because that's what they told me and while I was deployed I just decided to buy new H/O springs lash adjusters and H/O cams...why not? The heads were coming out anyway and so were the cams so it seemed like a good idea to upgrade at the time...to this day I haven't gotten the time to put them in but hopefully in the next three weeks I can make some time.
Old Jun 9, 2011 | 05:28 PM
why is it bad? i can never go back to conventional?
Old Jun 9, 2011 | 06:46 PM
hendrixx324
how long where you running synthetic?
I actualy dont no why you cant switch thats just what ive read.
Old Jun 9, 2011 | 07:10 PM
wingman_214's Avatar
wingman_214
There is almost no such thing as "synthetic", its all dead dinosaurs. Changing from synthetic to conventional will nit harm your engine. New oil is better than old wirn out oil.
