How about modifying your rear seat by raising it and put a sub board in under the seat. I would do that if I didn't have 2 carseats ion there for my lil guys. Just giving my 2 cents
I thought about something like this as well. I saw on a car show where they made a fiberglass mold of the spare tire hole in the trunk. So why couldnt we do this with the storage space under our back seats?? Yes it might cost a little bit of money, but it would completely custom and fit like a glove.
Modify was the key word. It would take time and $ but u could raise the rear seats. pretty sure it could be done. Is the bottom of the storage place actually sitting against the floor of the cab? Can the brackets to the seat get moved up to make the storage taller?
Yes you can unbolt the entire assembly, I found it easier then removing just one cushion. 4 Bolts, plus the seat belt bolt and it slides up and out. The problem you would encounter is the brackets that slide on the top section may end up a little to high and it won't support the seat position. You would have to extend the seat belts and find new hardware that is longer to hold it all to the floor.
