Need HELP 05 dakota keeps stalling
Old Jun 14, 2011 | 02:44 AM
dodgegirlT's Avatar
dodgegirlT
Question Need HELP 05 dakota keeps stalling
i have a 05 dakota, we have replaced the fuel pump, and the crankshaft position sensor. something is still shutting down the fuel pump, it will start(sometimes) and will idle a little bit, then the enging dies, sometimes while driving down the road it will die. after it dies there is not any fuel in the fuel rail..... Any Ideas?????
Old Jun 14, 2011 | 07:44 AM
wingman_214's Avatar
wingman_214
Could be lots of things. Is the check engine light on?
Bad fuel pump, try banging on the underside of the tank after it quits.
Dirt in the fuel tank clogging the pump.
Maybe a corroded connection at the pump, pull the connector and make sure its clean. Fuel pump relay on the fritz.
Bad chasis ground.
Pcm not providing ground.
Take it to a reputable shop and have them diagnose it.
Old Jun 14, 2011 | 01:24 PM
hendrixx324's Avatar
hendrixx324
how many miles... could be a clogged fuel filter
Old Jun 14, 2011 | 02:16 PM
do our trucks have the inertia switch like some cars have that shuts off the fuel pump?
Old Jun 14, 2011 | 03:07 PM
dodgegirlT's Avatar
dodgegirlT
The engine light is not on, doesn't show any codes when scanned.
Old Jun 14, 2011 | 03:10 PM
dodgegirlT's Avatar
dodgegirlT
I was told that there is NOT a switch that turns off the fuel pump
Old Jun 14, 2011 | 03:14 PM
dodgegirlT's Avatar
dodgegirlT
The fuel pump has been changed, along with the filter, and crank.p sensor,fuses have been checked. some days it will start,and then die, some days it won't start at all.
Old Jun 14, 2011 | 03:43 PM
moparman_2004's Avatar
moparman_2004
check to make sure you have constant power to the pump maybe losing power to the pump
Old Jun 14, 2011 | 08:46 PM
Deer Hunter's Avatar
Deer Hunter
My first thought would be the fuel pump relay. But a loose electrical connection teaming up with the rough idle or road vibration is another possibility. That could be a tough one.
Old Jun 14, 2011 | 09:29 PM
wingman_214
The fuel pump should have within + or - .5 volts of the battery.
