Weird problem.
Old Jun 27, 2011 | 06:50 AM
Backwoods18's Avatar
Backwoods18
Default Weird problem.
Hopefully somebody can help this puzzled guy out. I recently noticed a clunk in my front end. When I step on the brakes the I hear a pop and the clunk goes away. I checked tie rods, ball joints etc.. I checked the caliper on driver's side. I can move it with a pry bar, so I checked the mounting bolts and they are tight. Is this something more than a loose caliper? Or is there a way to tighten it up? Any help or tips would be appreciated. Thanks everybody.
Old Jun 27, 2011 | 09:09 AM
dakota_raven's Avatar
dakota_raven
My guess is a broken sway bar link! Check those. Sometimes the break and they look ok....
Old Jun 27, 2011 | 10:11 AM
wingman_214's Avatar
wingman_214
Is the caliper moving front to back or side to side? The caliper pins maybe worn out.
Old Jun 27, 2011 | 10:36 AM
Backwoods18
RAVEN: I dont have my front sway bar on atm.
WINGMAN: It moves front to rear not side to side and both calipers are 1 month old.
Old Jun 27, 2011 | 10:51 AM
dakota_raven
Old Jun 27, 2011 | 11:06 AM
wingman_214
The caliper should have no movement at all. make sure the caliper bolts are tight and that the caliper mounting braket is tight as well.
Old Jun 28, 2011 | 09:09 AM
Backwoods18
It was the mounting bracket that was loose. Thanks for the help.
